WFS GetFeature and GML data issue
Paul Ramsey
pramsey at REFRACTIONS.NET
Wed Mar 16 16:45:47 EST 2005
Hooray for the bounding box, our cruel task master! Let no query go
unbounded, and let the masses gnash their teeth, and quake in fear!
P
Kralidis,Tom [Burlington] wrote:
> Hi,
> After offline email with Frank (thanks Frank!), it seems that this has
> to do with the fact that my GML document bounding box of the data is
> outside of MAP/EXTENT in the mapfile. If I change my MAP/EXTENT to -180
> -90 180 90, I indeed get all the data back.
> I guess the question is the behaviour of MAP/EXTENT for a WFS, and if a
> LAYER has extents outside the bounds of MAP/EXTENT, what happens when a
> client makes a blanket request and expects all the data? Mind you if
> LAYER extents are larger than MAP/EXTENT, this should trigger the
> mapfile creator to think about whether they've applied the right
> MAP/EXTENT. On the other hand, how does MAP/EXTENT, something that
> historically applies to the default extent of a mapping app for
> MapServer CGI, apply to OWS approaches?
> At the very least (as Frank suggests) the WFS server howto should warn
> about this. I would post a doc bug for this but not until there is
> consensus that the way things behave now are the way they should.
> Comments?
> ..Tom
>>-----Original Message-----
>>From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
>>Sent: Wednesday, 16 March, 2005 15:20
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-DEV at lists.umn.edu
>>Subject: Re: [UMN_MAPSERVER-DEV] WFS GetFeature and GML data issue
>>On Wed, 16 Mar 2005 15:15:02 -0500, Kralidis,Tom [Burlington]
>><Tom.Kralidis at ec.gc.ca> wrote:
>>>Hi,
>>>I have a LAYER defined with a GML document as the native
>>data type.
>>>The GML document has 21 features.
>>>When I run a WFS GetFeature against the entire dataset:
>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.0.0&service=WFS&
>>>re
>>>quest=GetFeature&typename=neis&
>>>...I expect to have returned 21 features. However the
>>response only
>>>returns 4.
>>Tom,
>>How does this file look to ogrinfo? Can you post this GML
>>file for me to inspect?
>>Best regards,
>>I set the clouds in motion - turn up | Frank Warmerdam,
>>warmerdam at pobox.com
>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>and watch the world go round - Rush | Geospatial
>>Programmer for Rent
