WFS performance issue
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Mar 24 11:39:48 EST 2005
Frank Warmerdam wrote:
> On Thu, 24 Mar 2005 10:24:39 -0500, Yewondwossen Assefa
> <assefa at dmsolutions.ca> wrote:
>> I understand the this way of implementing complexe filters is not the
>>most optimal but Filters can become so complex that I need some kind of
>>logic and limitation to be able to adress all the cases.
> Assefa,
> As I understand it, we only have the opportunity for one SQL query
> to be evaluated in the RDBMS via the FILTER operator on a layer.
> What I would suggest is that if you find the query to be simple -
> that is a single bbox and/or one set of simple property operations then
> you convert the attribute queries into a FILTER and let the underlying
> provider take care of it.
Agreed. But there is even a limit when there is BBOX in the Filter. If
the BBOX is bundled with other opreations using the OR or Not operators,
the will necessite 2 separate queries. In case it is an AND I will
consider it as a simple filter.
> In all other circumsances just fallback to the existing approach
> which we have confidence works for complex cases. So we would
> basically just optimize simplier queries.
Agreed.
Thanks,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
