The EPSG Contract
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu May 19 15:27:25 EDT 2005
On 5/19/05, Paul Ramsey <pramsey at refractions.net> wrote:
> Is it so bad to suck it up and follow the standards consensus, no matter
> how silly? Sometimes bad decisions are made, but walking away from the
> process destroys all the good decisions too.
Paul,
I do see your point, and I have certainly accepted that when MapServer
implements WMS 1.3 it will have to address this issue properly. However,
the WFS stuff has existed for quite a while (as has GML) but this issue
is only being raised now in the WFS/GML context. So we are left
having to back-fix without any obvious indicate of what is really the right
thing to do.
I *suspect* that at least for GML 2 the coordinate system does not
control order of values in coordinate tuples. I'm sure I have heard
previous detailed discussios to this effect. I am not at all sure of
the situation with GML3.
Hopefully we can isolate these issues to GML3 and WMS 1.3+ so that
a simple version check will suffice to make the decision clear.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
