Carriage return/Line feed / space at end of line
Huub
hfl at HOME.NL
Wed Nov 9 11:37:27 EST 2005
A map file that looks like this in any editor
DATA "the_geom from (
select shapes.id_vsrg
, round(area(the_geom)) as opp
, address.ovb_regnr
, addressverh.ovb_regnr
, addressrheb.ovb_regnr
, address.gebdat
, vg_vsrgebieden.naam
, tdn_code
, round(x(centre)) as xcent
, round(y(centre)) as ycent
, shapes.oid as oid
, shapes.the_geom as the_geom
from shapes
inner join vg_vsr
on vg_vsr.id = shapes.id) ..."
can cause mapserv to crash (on linux):
This has something to do with linefeeds and carriage returns:
a single white space at the end of every file seems to be necessary
If you edit a mapfile on windows and then copy it to a linux machine
there is the danger that this white space is not there
a acsii 10 (\n or LF ) is not considered to be whitespace it seems.
a ascii 13 (\r or CR) is considered to be whitspace.
If you have to move from windows to linux, and try to remove first these
^M signals that appear in VI, messes things op.
How can this happen? Shouldn't a \n or \r\n or \r be treated the same
in a platform independent product?
Is this a bug?
The mapserver version that i'm talking about is linux (debian) 4.4.1
Is it better in 4.6.1?
Regards,
Huub
