Carriage return/Line feed / space at end of line
Huub Fleuren
hfl at HOME.NL
Thu Nov 10 15:19:12 EST 2005
Thanks Frank,
for the tip.
I would do it, if I had the time.
Also I don't have easy access to the machine.
Also I'm always on a windoos (that's dutch (pronounce dose, like hose or
-dows) : doos = box, but also a not at all too witty person)
Sorry this time.
Huub
Frank Warmerdam wrote:
>On 11/10/05, Huub Fleuren <hfl at home.nl> wrote:
>>Hi Frank,
>>For us it is both risky and too time consuming to upgrade (recompile) on
>>debian.
>>(i've been stuck on this for almost a week on this allready)
>Huub,
>You can install FWTools 1.0.0a6 for Linux on Debian. It is completely
>self contained (won't mess anything existing up) and should include postgis
>support. You can setup a minimal .map file that you think demonstrates
>the problem and it should be relatively easy for someone else to take that
>and run with it.
>>I suppose that it can be checked with any of your own testcases for
>>POSTGRESQL
>Well, possibly, but it could also lead some developer on a wild goose
>chance trying to reproduce things. I can't speak for all the other developers
>but I for one prefer to push as much work as possible onto the bug reporter
>unless I have a financial incentive (or the reporter has a good deal of
>"contributor mojo" on account already).
>>I have some more info for you though.
>>The error was found after the truncated DATA statement in the
>>mapserv.log file appeared not to execute in pgAdmin if the lines end in
>>a table_name
>>compare:
>>"select blabla from table_name inner join table_name... " = ok
>> inner join table_name... " = not ok
>>Is the next line is concatenated to the name in postgres?
>>(where a cr is whitespace and lf is not (once in postgres))
>>So it may be a bug in postgres, but than mapserver is the client: maybe
>>put the complete statement in one line, inserting whitespace where
>>appropriate?
>I'm not sure I follow all this. But it just makes it all the more
>important to provide an easy to reproduce test case.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
