Mapserver Postgis driver problem with EWKB
Frank Warmerdam warmerdam at POBOX.COM
Tue Nov 22 17:41:33 EST 2005
On 11/22/05, Tamas Szekeres <szekeres.tamas at freemail.hu> wrote:
> It seems that the OGR postgis driver does not suffer with this problem
Tamas,
Modern OGR versions should be ok, but if there is actually a problem
with the mappostgis.c implementation in MapServer 4.8 it would
be much appreciated if you could submit a detailed bug report on
the issue.
We certainly don't want MapServer 4.8 shipping without
good built-in PostGIS support.
Best regards,
