issue with latest CVS
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Fri Oct 7 19:25:39 EDT 2005
I am having problems with latest CVS against an OWS which has been
functioning normally until sometime this week.
Request URL:
http://devgeo.cciw.ca/cgi-bin/mapserv/owscat?version=1.0.0&service=WFS&r
equest=GetFeature&typename=service_resources&filter=%3CFilter%3E%3CAnd%3
E%3CBBOX%3E%3CPropertyName%3ENAME%3C/PropertyName%3E%3CBox%20srsName='EP
SG:4326'%3E%3Ccoordinates%3E-139,48%20-114,60%3C/coordinates%3E%3C/Box%3
E%3C/BBOX%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Eservice_type%3C/Pro
pertyName%3E%3CLiteral%3EOGC:WMS%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3
COr%3E%3COr%3E%3CPropertyIsLike%20wildCard='*'%20singleChar='.'%20escape
='!'%3E%3CPropertyName%3Etitle%3C/PropertyName%3E%3CLiteral%3E*water*%3C
/Literal%3E%3C/PropertyIsLike%3E%3CPropertyIsLike%20wildCard='*'%20singl
eChar='.'%20escape='!'%3E%3CPropertyName%3Eabstract%3C/PropertyName%3E%3
CLiteral%3E*water*%3C/Literal%3E%3C/PropertyIsLike%3E%3C/Or%3E%3CPropert
yIsLike%20wildCard='*'%20singleChar='.'%20escape='!'%3E%3CPropertyName%3
Ekeywords%3C/PropertyName%3E%3CLiteral%3E*water*%3C/Literal%3E%3C/Proper
tyIsLike%3E%3C/Or%3E%3C/And%3E%3C/Filter%3E&outputFormat=GML3
This gives me a 500 where it never did before.
Running this through gdb gives me the output below.
I saw two changes this week to  mapogcfilter.c.  Perhaps that is the
issue?
..Tom
(gdb) set args
QUERY_STRING="map=/usr/local/wwwsites/apache/devgeo.cciw.ca/apps/mapserv
/services/owscat/config.map&version=1.0.0&service=WFS&request=GetFeature
&typename=service_resources&filter=<Filter><And><BBOX><P
ropertyName>NAME</PropertyName><Box
srsName='EPSG:4326'><coordinates>-139,48
-114,60</coordinates></Box></BBOX><PropertyIsEqualTo><PropertyName>servi
ce_type</PropertyName><Literal>OGC:WMS</Literal></PropertyIsEqualT
o><Or><Or><PropertyIsLike wildCard='*' singleChar='.'
escape='!'><PropertyName>title</PropertyName><Literal>*water*</Literal><
/PropertyIsLike><PropertyIsLike wildCard='*' singleChar='.'
escape='!'><PropertyName>abst
ract</PropertyName><Literal>*water*</Literal></PropertyIsLike></Or><Prop
escape='!'><PropertyName>keywords</PropertyName><Literal>*water*</Litera
l></PropertyIsLike></Or></And></
Filter>&outputFormat=GML3"
(gdb) r
Starting program: /usr/local/bin/mapserv
lter=<Filter><And><BBOX><PropertyName>NAME</PropertyName><Box
Literal></PropertyIsEqualTo><Or><Or><PropertyIsLike wildCard='*'
singleChar='.'
/PropertyIsLike><PropertyIsLike wildCard='*' singleChar='.' esc
ape='!'><PropertyName>abstract</PropertyName><Literal>*water*</Literal><
/PropertyIsLike></Or><PropertyIsLike wildCard='*' singleChar='.'
l></Pr
opertyIsLike></Or></And></Filter>&outputFormat=GML3"
[Thread debugging using libthread_db enabled]
[New Thread -1208061824 (LWP 7681)]
[Fri Oct  7 20:02:26 2005].282934 msPOSTGISLayerOpen called
datastatement: the_geom from (select service_endpoints.organization as
organization,service_endpoints.endpoint_getresource as
endpoint_getresource,service_
endpoints.service_type as service_type,service_endpoints.service_version
as service_version,service_resources.the_geom as
the_geom,service_resources.resource_id as
resource_id,service_resources.service_id as service
_id,service_resources.name as name,service_resources.title as
title,service_resources.abstract as abstract,service_resources.keywords
as keywords,service_resources.dataurl as
dataurl,service_resources.metadataurl as
 metadataurl,service_resources.legendurl as
legendurl,service_resources.scale_min as
scale_min,service_resources.scale_max as scale_max,service_resources.srs
as srs,service_endpoints.format_list as format_list,servi
ce_resources.style_list as style_list,service_resources.time_extent as
time_extent,service_resources.queryable as queryable from
service_resources inner join service_endpoints on
service_endpoints.service_id = servi
ce_resources.service_id) as t using unique resource_id
[Fri Oct  7 20:02:26 2005].284666 MSPOSTGISLayerOpen -- shared
connection not available.
[Fri Oct  7 20:02:26 2005].327541
msConnPoolRegister(service_resources,user=postgres
dbname=devgeodb,0x82f1918)
[Fri Oct  7 20:02:26 2005].327961 msPOSTGISLayerFreeItemInfo called
[Fri Oct  7 20:02:26 2005].328207 msPOSTGISLayerWhichShapes called
[Fri Oct  7 20:02:26 2005].328584 msPOSTGISLayerParseData: unique column
= resource_id, srid='', geom_column_name = the_geom, table_name=(select
service_endpoints.organization as organization,service_endpoints.endpo
int_getresource as endpoint_getresource,service_endpoints.service_type
as service_type,service_endpoints.service_version as
the_geom,service_resources.resource_id as res
service_id,service_resources.name as name,service_resources.title as
aurl as dataurl,service_resources.metadataurl as
as srs,se
rvice_endpoints.format_list as format_list,service_resources.style_list
ndpoints on service_endpoints.service_id = service_resources.service_id)
as t
[Fri Oct  7 20:02:26 2005].331242 query_string_0_6:DECLARE mycursor
BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),resource_id::text
from (select service_endpoints.organization as orga
endpoint_getresource,service_endpoints.service_type as
service_version,service_resources.the_geom as the_geom,serv
ice_resources.resource_id as resource_id,service_resources.service_id as
a
,service_resources.srs as srs,service_endpoints.format_list as
format_list,service_resources.style_list as
time_extent,service_resources.queryable as queryable from servic
e_resources inner join service_endpoints on service_endpoints.service_id
= service_resources.service_id) as t WHERE ( (service_type= 'OGC:WMS')
And  ( (!'!'titie e keke%w%werer e eapap')  Or !'!'ababrara l le e waw
ar%r%esespepe) )  Or !'!'kekeoror l le e wawar%r%esespepe) ) ) and
(the_geom && setSRID( 'BOX3D(-139 48,-114
60)'::BOX3D,find_srid('','service_resources','the_geom') ))
[Fri Oct  7 20:02:26 2005].347362 msPOSTGISLayerFreeItemInfo called
[Fri Oct  7 20:02:26 2005].347664 msPOSTGISLayerClose datastatement:
nts.service_type as service_type,service_endpoints.service_version as
resource_id,service_resources.service_id as service_id,se
dataurl,service_resources.metadataurl as metad
as srs,service_endpoints.format_list as format_list,service_res
[Fri Oct  7 20:02:26 2005].349031 msPOSTGISLayerClose -- query_result is
NULL
[Fri Oct  7 20:02:26 2005].349134
msConnPoolRelease(service_resources,user=postgres
[Fri Oct  7 20:02:26 2005].349246 msConnPoolClose(user=postgres
Content-type: text/xml
<?xml version='1.0' encoding="ISO-8859-1" ?>
<owscat:msFeatureCollection
   xmlns:owscat="http://www.ec.gc.ca/owscat"
   xmlns:gml="http://www.opengis.net/gml"
   xmlns:ogc="http://www.opengis.net/ogc"
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
   xsi:schemaLocation="http://www.ec.gc.ca/owscat
http://devgeo.cciw.ca/cgi-bin/mapserv/owscat?SERVICE=WFS&amp;VERSION=1.0
.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=service_resources&amp;OU
TPUTFORMAT=SFE_XMLSCH
EMA">
   <gml:boundedBy>
      <gml:null>missing</gml:null>
   </gml:boundedBy>
</owscat:msFeatureCollection>
[Fri Oct  7 20:02:26 2005].356855 msPOSTGISLayerClose datastatement:
the_geom from service_endpoints
[Fri Oct  7 20:02:26 2005].357098 msPOSTGISLayerClose -- layerinfo is
NULL
[Fri Oct  7 20:02:26 2005].357321 msPOSTGISLayerClose datastatement:
[Fri Oct  7 20:02:26 2005].358653 msPOSTGISLayerClose -- layerinfo is
NULL
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1208061824 (LWP 7681)]
msResetErrorList () at maperror.c:267
267           next_error = this_error->next;
