MS RFC 8: Pluggable External Feature Layer Providers
Sean Gillies
sgillies at FRII.COM
Thu Oct 27 09:34:51 EDT 2005
On Oct 27, 2005, at 7:03 AM, Daniel Morissette wrote:
> Sean Gillies wrote:
>> I want to be able to use absolute paths instead of a combination of
>> relative path and environment variable or config property, and I
>> think
>> others will also want this option.
> Can you please explain why that's needed? Is this simply because you
> don't want to be forced to place all your plugins in the same
> directory
> or are there other reasons?
1. Right, I don't want to be restricted to a single plugin location.
2. We allow absolute paths to shapefiles, allowing the same for
plugins eliminates yet another special case. Simplicity and
uniformity are better.
> If we allowed the PLUGIN arg to contain path components relative to
> the
> MS_PLUGIN_DIR var *if it is set*, just like the DATA statement works
> relative to the SHAPEPATH, but not the .so/.dll extension then would
> that do the trick for you?
> e.g.
> MAP
> CONFIG "MS_PLUGIN_DIR" "/opt/mapserver/plugins"
> LAYER
> CONNECTIONTYPE CUSTOM
> PLUGIN "/path/to/anotherdir/myplugin"
> END
> LAYER
> PLUGIN "myplugin"
> END
> END
Fine with me. I can see how a directory of plugins will be useful for
products like ms4w, but it would actually impede me. If we can have
each, that's great.
>> Jani,
>> What would you think about a change from CONNECTIONTYPE CUSTOM ->
>> CONNECTIONTYPE PLUGIN? I think that the meaning of "PLUGIN" will be
>> more clear to users.
> I like this idea.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
Sean Gillies
sgillies at frii.com
http://zcologia.com
