Mapserver compilation with mygis on windows
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Mon Sep 5 08:59:04 EDT 2005
Carsten,
place
#define u_int16_t short
#define u_int32_t long
somewhere at the top of mapmygis.c. That should do the trick.
Anyway, AFAIK MyGIS support for mapserver has been discontinued as for
the 4.6 release. So you'll probably have a hard time if you need further
help on this topic as there aren't many experienced users of MyGIS
around any more (at least I think so).
Regards,
Andreas
Carsten Münchenbach wrote:
> Hi Andreas,
> thanks for the hint. It worked for mapjoin.c. But now it runs into errors
> for mapmygis.c. I kind of expected it because I searched for the occurence
> of <mysql/mysql> in all files and found it there. I also added #include
> <winsock.h> as you recommended for mapmygis.c. But obviously there is also
> something else missing. It's beyond my knowledge of c++ to find out what. Do
> you or someone else got an idea? (tell me if I should translate the error
> messages)
> Thank you very much for your help,
> Carsten
> here are the subsequent compilation errors:
> ... AS -DUSE_MYGIS /c mapmygis.c /Fomapmygis.obj
> mapmygis.c
> mapmygis.c(246) : error C2065: 'u_int16_t' : nichtdeklarierter Bezeichner
> mapmygis.c(246) : error C2065: 'shorts' : nichtdeklarierter Bezeichner
> mapmygis.c(246) : warning C4047: '=' : Anzahl der Dereferenzierungen bei
> 'int ' und 'void *' unterschiedlich
> mapmygis.c(246) : error C2106: '=' : Linker Operand muss ein L-Wert sein
> mapmygis.c(247) : error C2065: 'u_int32_t' : nichtdeklarierter Bezeichner
> mapmygis.c(247) : error C2065: 'longs' : nichtdeklarierter Bezeichner
> mapmygis.c(247) : warning C4552: '*' : Operator hat keine Auswirkungen;
> Operator mit Seiteneffekt erwartet
> mapmygis.c(258) : error C2059: Syntaxfehler : ')'
> mapmygis.c(259) : error C2100: Zeigeroperation ungueltig
> mapmygis.c(262) : error C2059: Syntaxfehler : ')'
> mapmygis.c(263) : error C2100: Zeigeroperation ungueltig
> mapmygis.c(266) : error C2059: Syntaxfehler : ')'
> mapmygis.c(267) : error C2100: Zeigeroperation ungueltig
> mapmygis.c(269) : error C2100: Zeigeroperation ungueltig
> mapmygis.c(277) : error C2143: Syntaxfehler : Fehlendes '{' vor '*'
> mapmygis.c(313) : warning C4244: '=' : Konvertierung von 'unsigned __int64 '
> in 'int ', moeglicher Datenverlust
> mapmygis.c(511) : warning C4047: '=' : Anzahl der Dereferenzierungen bei
> 'char ' und 'void *' unterschiedlich
> NMAKE : fatal error U1077: 'cl' : Rueckgabe-Code '0x2'
> Stop.
> On Mon, 5 Sep 2005 12:54:33 +0200, Andreas Albarello
> <andreas.albarello at TERRITORIUMONLINE.COM> wrote:
>>Carsten,
>>you may try to replace
>>#ifndef _mysql_h
>>#include <c:\projects\mysql\include\mysql.h>
>>#endif
>>with the following:
>>#ifndef _mysql_h
>>#include <winsock.h>
>>#endif
>>Hope this helps.
>>Best regards,
>>Andreas Albarello
>>Analysis & SW Development
>>Territorium Online srl/GmbH
>>Via Siemens-Straße 19 - I 39100 Bolzano/Bozen
>>email: andreas.albarello at territoriumonline.com
>>web: www.territoriumonline.com
>>>That's what I did: I'm sorry that I forgot to give you copies of the file:
>>>That's the path to MySQL Version 3.23.58 binary distribution, installed and
>>>works
>>>C:\projects\mysql
>>>here the concerning rows:
>>>in NMAKE.opt
>>>#MYGIS
>>>MYGIS_DIR = c:\projects\mysql
>>>MYGIS=-DUSE_MYGIS
>>>#MyGIS support
>>>!IFDEF MYGIS
>>>MYGIS_INC=-I$(MYGIS_DIR)\include
>>>MYGIS_LIB=$(MYGIS_DIR)\lib\opt\libmysql.lib "C:\Programme\Microsoft Visual
>>>Studio\VC98\Lib\advapi32.lib"
>>>!ENDIF
>>>EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
>>> $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
>>> $(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
>>> $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
>>> $(ORACLE_LIB) $(MYGIS_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB)
>>>LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
>>>LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
>>>INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
>>> $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
>>> $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
>>> $(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(MYGIS_INC) $(SDE_INC)\
>>> $(ICONV_INC) $(FCGIINC)
>>>MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS) -DWIN32 -D_WIN32 \
>>> $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) $(THREADS) \
>>> $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
>>>$(NEED_NONBLOCKING_STDERR) $(ENABLE_STDERR_DEBUG) \
>>> $(USE_POINT_Z_M) $(GDAL) $(FCGIDEF) \
>>> $(WFS) $(WFSCLIENT) $(WCS) $(PDF) $(EGIS) \
>>> $(USE_GD_ANTIALIAS) $(ORACLE) $(MYGIS) $(MING_VERSION) $(SDE_OPT)
>>>$(ICONV)
>>>MS_CFLAGS=$(INCLUDES) $(MS_DEFS)
>>>But still the same error. I looked up the mapjoin.c file at row 486
>>>#ifndef _mysql_h
>>>#include <mysql/mysql.h>
>>>#endif
>>>I don't know why _mysql_h is not defined.
>>>If I change it to
>>>#ifndef _mysql_h
>>>#endif
>>>with my Path, mysql.h is found but the errors getting even more worse:
>>>c:\projects\mysql\include\mysql_com.h(117) : error C2061: Syntaxfehler :
>>>Bezeichner 'SOCKET'
>>>c:\projects\mysql\include\mysql_com.h(132) : error C2059: Syntaxfehler : '}'
>>>c:\projects\mysql\include\mysql_com.h(162) : error C2143: Syntaxfehler :
>>>Fehlendes ')' vor '*'
>>>a.s.o.
>>>such syntax error in the mysql files that just can't be. I use the binary
>>>distribution for windows.
>>>Thanks for your help so far,
>>>Carsten
>>>On Mon, 5 Sep 2005 11:00:04 +0200, Bart van den Eijnden
>>><BEN at SYNCERA-ITSOLUTIONS.NL> wrote:
>>>>You need to download mysql and set the correct path in nmake.opt.
>>>>Best regards,
>>>>Bart
>>>>Syncera IT Solutions
>>>>Postbus 270
>>>>2600 AG DELFT
>>>>tel.nr.: 015-7512436
>>>>email: BEN at Syncera-ITSolutions.nl
>>>>>>>=?ISO-8859-15?Q?Carsten_M=FCnchenbach?= <map at HYDRARGYRUM.DE> 09/05/05
>>>10:43 am >>>
>>>>Hi all,
>>>>I manage to get MapSeerver compiled on Windows XP. It works fine without
>>>>the mygis option. But know I urgently need MapServer with MyGIS support.
>>>>Unfortunately I'm running into an error:
>>>>cl /nologo /MD /W3 /DDEBUG -Ic:/projects/gdwin32 -Ic:\projects\proj-
>>>>4.4.9/src -Ic:\projects\php-4.3.11/regex -DPHP_NO_ALIASES
>>>>-Ic:\projects\gdal-1.2.6/gcore -Ic:\projects\gdal-1.2.6/alg
>>>>-Ic:\projects\gdal-1.2.6/ogr -Ic:\projects\gdal-1.2.6/port
>>>>-Ic:\projects\gdal-1.2.6/ogr/ogrsf_frmts -Ic:\projects\gdal-1.2
>>>>.6/ogr -Ic:\projects\gdal-1.2.6/port -Ic:/projects/curl-7.14.0/include
>>>>-Ic:/projects/pdflib-6.0.0/pdflib -Ic:\projects\mysql\include
>>>>-DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
>>>>-DNEED_STRLCAT -DWIN32 -D_WIN32 -DUSE_PROJ -DUSE_PROJ_API_H
>>>>-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF
>>>>-DGD_HAS_GDIMAGEGIFPTR -DUSE_GD_FT -DGD_HAS_GETBITMAPFONT -DUSE_OGR
>>>>-DUSE_WMS_SVR -DUSE_WMS_LYR -DIGNORE_MISSING_DATA
>>>>-DENABLE_STDERR_DEBUG -DUSE_GDAL -DUSE_WFS_SVR -DUSE_WFS_LYR
>>>>-DUSE_WCS_SVR -DUSE_PDF -DUSE_GD_ANTIALI
>>>>AS -DUSE_MYGIS /c mapjoin.c /Fomapjoin.obj
>>>>mapjoin.c
>>>>mapjoin.c(486) : fatal error C1083: Include-Datei kann nicht geoeffnet
>>>>werden: 'mysql/mysql.h': No such file or directory
>>>>What's going wrong? Ideas are ver appreciated!
>>>>Thanks,
>>>>Carsten
Andreas Albarello
