mapscript build error
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Sep 8 19:12:08 EDT 2005
I just updated latest CVS (I update and build every couple of days or
so) and found a problem when building php mapscript as part of my usual
process:
$./configure --enable-debug
--with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/
--with-png=/usr/local/ --with-jpeg=/usr/local/ --with-xpm
=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl
--with-proj=/usr/local --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin
/gdal-config --without-tiff
--with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs
--with-wmsclient --with-wfsclient --with-curl-config=/usr/l
ocal/bin/curl-config --with-php=/usr/local/src/php/php-5.0.5
$make
[snip of everything that compiled fine before this]
gcc -fPIC -g -O2 -fPIC -Wall -DUSE_PHP_REGEX -DCOMPILE_DL=1 -DPHP4
-DENABLE_STDERR_DEBUG -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_WCS_SVR
-DUSE_WFS_SVR -DUSE_W
MS_SVR -DUSE_POSTGIS -DUSE_GDAL -DUSE_OGR -DUSE_PROJ -DUSE_EPPL
-DUSE_PDF -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_H
AS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB
-I/usr/local/src/mapserver/cvs/mapserver
-I/usr/local/src/php/php-5.0.5/regex/.. -I/usr/l
ocal/include -I/usr/local/pgsql/include -I/usr/local/include
-I/usr/local/include -I/usr/local/include -I/usr/local/include
-I/usr/local//include -
I/usr/local/src/php/php-5.0.5 -I/usr/local/src/php/php-5.0.5/dl
-I/usr/local/src/php/php-5.0.5/main -I/usr/local/src/php/php-5.0.5/Zend
-I/usr/local/src/ph
p/php-5.0.5/include -I/usr/local/src/php/php-5.0.5/TSRM
-I/usr/local/src/php/php-5.0.5/regex/.. -c -o
/usr/local/src/php/php-5.0.5/regex/regerror.o /usr/l
ocal/src/php/php-5.0.5/regex/regerror.c
/usr/local/src/php/php-5.0.5/regex/regerror.c:38: error: `REG_OKAY'
undeclared here (not in a function)
/usr/local/src/php/php-5.0.5/regex/regerror.c:38: error: initializer
element is not constant
/usr/local/src/php/php-5.0.5/regex/regerror.c:38: error: (near
initialization for `rerrs[0].code')
initialization for `rerrs[0]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:39: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:39: error: (near
initialization for `rerrs[1]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:40: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:40: error: (near
initialization for `rerrs[2]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:41: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:41: error: (near
initialization for `rerrs[3]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:42: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:42: error: (near
initialization for `rerrs[4]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:43: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:43: error: (near
initialization for `rerrs[5]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:44: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:44: error: (near
initialization for `rerrs[6]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:45: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:45: error: (near
initialization for `rerrs[7]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:46: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:46: error: (near
initialization for `rerrs[8]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:47: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:47: error: (near
initialization for `rerrs[9]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:48: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:48: error: (near
initialization for `rerrs[10]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:49: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:49: error: (near
initialization for `rerrs[11]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:50: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:50: error: (near
initialization for `rerrs[12]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:51: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:51: error: (near
initialization for `rerrs[13]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:52: error: `REG_EMPTY'
/usr/local/src/php/php-5.0.5/regex/regerror.c:52: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:52: error: (near
initialization for `rerrs[14].code')
initialization for `rerrs[14]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:53: error: `REG_ASSERT'
/usr/local/src/php/php-5.0.5/regex/regerror.c:53: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:53: error: (near
initialization for `rerrs[15].code')
initialization for `rerrs[15]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:54: error: `REG_INVARG'
/usr/local/src/php/php-5.0.5/regex/regerror.c:54: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:54: error: (near
initialization for `rerrs[16].code')
initialization for `rerrs[16]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:55: error: initializer
/usr/local/src/php/php-5.0.5/regex/regerror.c:55: error: (near
initialization for `rerrs[17]')
/usr/local/src/php/php-5.0.5/regex/regerror.c:64: error: syntax error
before "php_regerror"
/usr/local/src/php/php-5.0.5/regex/regerror.c:65: warning: return type
defaults to `int'
/usr/local/src/php/php-5.0.5/regex/regerror.c: In function
`php_regerror':
/usr/local/src/php/php-5.0.5/regex/regerror.c:72: error: `REG_ITOA'
undeclared (first use in this function)
/usr/local/src/php/php-5.0.5/regex/regerror.c:72: error: (Each
undeclared identifier is reported only once
/usr/local/src/php/php-5.0.5/regex/regerror.c:72: error: for each
function it appears in.)
/usr/local/src/php/php-5.0.5/regex/regerror.c:76: error: `REG_ATOI'
/usr/local/src/php/php-5.0.5/regex/regerror.c: In function `regatoi':
/usr/local/src/php/php-5.0.5/regex/regerror.c:119: error: structure has
no member named `re_endp'
make[1]: *** [/usr/local/src/php/php-5.0.5/regex/regerror.o] Error 1
make[1]: Leaving directory
`/usr/local/src/mapserver/cvs/mapserver/mapscript/php3'
