RFC 4: MapServer Raster Resampling
Steve Lime steve.lime at DNR.STATE.MN.US
Fri Sep 16 20:56:59 EDT 2005
+1
>>> Frank Warmerdam <warmerdam at POBOX.COM> 09/16/05 12:14 PM >>>
MS RFC 4: MapServer Raster Resampling
:Date:  2005/09/16
:Author: Frank Warmerdam
:Contact: warmerdam at pobox.com
:Last Edited: $Date: 2005/09/16 $
:Status: proposed
Overview
Additional resampling kernels will be implemented in the MapServer GDAL
raster resampler code including "averaging", "bilinear" and "cubic".
Technical Details
 o The new resampling options will be implemented in mapresample.c and will
   only be accessable for datasets processing through that mechanism (ie.
   GDAL raster formats, requires coordinate system information defined).
 o The resampling kernel to use will be selected with one of the following.
   The default will be RESAMPLE=NEAREST, the current behavior.
     PROCESSING "RESAMPLE=NEAREST"
     PROCESSING "RESAMPLE=AVERAGE"
     PROCESSING "RESAMPLE=BILINEAR"
     PROCESSING "RESAMPLE=CUBIC"
 o The mapraster.c code currently decides whether to invoke the "simple"
   GDAL renderer or the "resampling" GDAL renderer based on whether the
   projection seems to differ.  It will also now check for the RESAMPLE
   processing option, and force use of mapresample.c if the resampling
   kernel select is other than NEAREST.
 o Note that resampling kernels other than NEAREST can have a substantial
   effect on rendering performance.   For this reason NEAREST will remain
   the default.
Mapfile Implications
All new options are selected via new PROCESSING options.   There is
no change in the mapfile syntax.  There should be no compatbability problems
with old mapfiles.
MapScript Implications
There are no additions or changes to the mapscript API.  The new
options are controlled via PROCESSING information on the layers which I
believe is already manipulatable from mapscript.
Documentation Implications
The new processing options will need to be documented in the Raster HOWTO
(and possibly the mapfile reference).
Test Plan
New test cases for each mode will be incorporated in msautotest/gdal.
Staffing / Timeline
The new feature will be implemented by Frank Warmerdam and completed
by October 15th in time for the MapServer 4.8 release.   Implementation
is generously funded by Tydac AG and managed by DM Solutions.
