MS RFC 7: MapServer CVS Commit Management
Frank Warmerdam
warmerdam at POBOX.COM
Wed Sep 28 15:41:42 EDT 2005
On 9/28/05, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
> In order to avoid making this process too heavy, would it be sufficient
> to include a note like the following?
> - When committing new features or significant changes to existing source
> code, the committer should take reasonable measures to insure that the
> source code continues to build and work on the most commonly supported
> platforms (currently Linux and Windows), either by testing on those
> platforms directly, or by getting help from other developers working on
> those platforms. If new files or library dependencies are added, then
> the configure.in, Makefile.in, Makefile.vc and related documentations
> should be kept up to date.
Assefa / Daniel,
I have added the above comment.
I will take this opportunity to vote +1 on my own proposal.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
