windows buildkit, regex change
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Sun Apr 2 09:24:00 EDT 2006
Hi Howard, list,
the regex you provide in your buildkit is not compatible with Visual
Studio 8, would you be able to change that? I am pretty positive this
would also work with Visual Studio 7.1, but cannot check that out here.
Maybe somebody else can check that?
In regex.c (line 4875), the following old-style function declaration
should be changed from:
size_t
regerror (errcode, preg, errbuf, errbuf_size)
    int errcode;
    const regex_t *preg;
    char *errbuf;
    size_t errbuf_size;
to:
size_t regerror( int errcode, const regex_t* preg, char* errbuf, size_t
errbuf_size)
otherwise you get the following with Visual Studio 8:
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4876) : error C2081:
'preg' :
name in formal parameter list illegal
'errbuf'
: name in formal parameter list illegal
'errbuf_s
ize' : name in formal parameter list illegal
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4877) : error C2055:
expected
formal parameter list, not a type list
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4877) : error C2082:
redefinit
ion of formal parameter 'errcode'
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4885) : warning C4996:
'errcod
e' was declared deprecated
        C:\Program Files\Microsoft Visual Studio
8\VC\INCLUDE\crtdefs.h(393) : s
ee declaration of 'errcode'
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4885) : error C2059:
syntax er
ror : 'type'
c:\buildkit\mapserver-4.8.3\..\regex-0.12\regex.c(4893) : error C2275:
'errcode'
 : illegal use of this type as an expression
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\c
l.exe"' : return code '0x2'
Stop.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
