antialiasing stuff
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Mon Apr 3 13:18:23 EDT 2006
Guys,
did the hardness parameter ever get exposed to the MAP file?
If not, is there a workaround? Thanks.
Best regards,
Bart
Daniel Morissette wrote:
> After seeing how you had to tune the hardness value in order to get
> the best possible looking maps, I agree that just soft and hard might
> not be enough, especially when at the lower level the range of valid
> values is much larger than that.
> My main concern would be to not break backwards compatibility with
> older mapfiles (even if antialias never really worked before). We'd
> have to make sure that ANTIALIAS TRUE/FALSE are still supported by the
> parser, with some acceptable default for the TRUE case.
> BTW, isn't the internal hardness value a float in the 0.0-1.0 range?
> If that's the case then that's what we should offer in the mapfile too.
> Daniel
> Paul Spencer wrote:
>> That seems to go against other aspects of mapserver's design where
>> full control is provided at the expense of some complexity.
>> Whatever gets picked will never be quite right for some people. I
>> think the extra complexity can be adequately controlled by
>> documenting reasonable values for 'soft', 'medium', and 'hard' and
>> what the effect is on the output.
>> Cheers
>> Paul
>> On 14-Jan-06, at 11:15 AM, Sean Gillies wrote:
>>> IMO, that's more control than people need. How about a few flavors
>>> of antialiasing like "soft" and "hard".
>>> Sean
>>> On Jan 14, 2006, at 8:56 AM, Paul Spencer wrote:
>>>> Would it make sense to change the meaning of the antialias tag in the
>>>> style and change it to a 0-100 value instead of a true/false? If you
>>>> don't want to antialias a layer, then you wouldn't put ANTIALIAS
>>>> FALSE, you'd just remove it altogether. So in the case of using
>>>> antialias as an integer value, it would make sense.
>>>> Paul
>>>> On 13-Jan-06, at 4:38 PM, Yewondwossen Assefa wrote:
>>>>> I have not seen an equivalent term in the sld specs.
>>>>> Steve Lime wrote:
>>>>>> I think in the next version we could expose the hardness setting
>>>>>> to mapfile
>>>>>> tweaking... What's the equivalent terminiology in something like
>>>>>> SLD?
>>>>>> Steve
>>>>>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 2:43 PM >>>
>>>>>> cool, thanks :) I hadn't tried it, thought I would ask first.
>>>>>> I've managed to achieve almost the desired effect by jacking the
>>>>>> hardness to 0.95 and fixing the gd bug for 1 pixel lines since I
>>>>>> asked so maybe we won't end up going this route.
>>>>>> Cheers
>>>>>> Paul
>>>>>> PS: any chance of having a HARDNESS keyword at the style level?
>>>>>> On 13-Jan-06, at 2:55 PM, Steve Lime wrote:
>>>>>>> This should be doable "as is". Just set TRANSPARENCY ALPHA and
>>>>>>> point
>>>>>>> to the right image in your style or symbol definition. All the
>>>>>>> fuzzy brush
>>>>>>> support does is do this programatically.
>>>>>>> I believe I've tested this before using an image or two that
>>>>>>> Sean had created
>>>>>>> while fixing another bug.
>>>>>>> Have you tried it and it doesn't work?
>>>>>>> Steve
>>>>>>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 12:59 PM >>>
>>>>>>> Steve,
>>>>>>> what would it take to support rendering lines with custom symbols
>>>>>>> that have alpha transparency in them? We would like to be able to
>>>>>>> make our own brushes that work in the same way that fuzzy brushes
>>>>>>> work, but we pre-render them and access them as symbols. This
>>>>>>> would
>>>>>>> allow finer control over styling without having to tweak mapserver
>>>>>>> code to get the desired effect :)
>>>>>>> Cheers
>>>>>>> Paul
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Applications & Software Development |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/|
OSGIS, Open Source GIS
http://www.osgis.nl
