Updated RFC 14...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Apr 13 13:34:16 EDT 2006
Steve,
This looks great.
Since you are changing the starting value of the positions enumeration,
this will likely effect any mapscript code that is using numeric values
instead of the symbol names that are exported into mapscript. While this
is just poor programming on the mapscript user's part, you could
probably add a note to the Backwards compatibility section to this
regard since it is possible to set enum values with numbers.
-Steve
Steve Lime wrote:
> Hi all: Based on feedback earlier in the week I have revised the RFC for relatively
> positioned features a good bit. Thanks to all who commented, it was very helpful.
> The RFC can be viewed at:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-14
> Steve
