request for new mapserver features
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 24 11:21:15 EDT 2006
Frank Warmerdam wrote:
> Peter Freimuth (MapMedia GmbH) wrote:
[snip]
>> - draw a symbol at the center of polygons or lines (it is possible for
>> labels so why not using the label offset point for symbol placement in
>> the same way); it is possible to solve this inside of PostGIS, but i
>> think it would also be a nice function for other datasources.
> This seems quite reasonable to me, though I don't know the details of
> what would be needed to implement it. If you are so inclined, perhaps you
> could prepare a patch implementing this. If it is non-disruptive Steve
> could likely commit it without further complication. If it requires any
> sort of changes to mapfile syntax or has other possible compatibility
> issues an RFC would likely be needed.
There is a bug the covers improved label positioning that might be the
appropriate place to start.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1592
If you think this generally covers your needs as is or with some
extensions, please add your comments to the bug.
-Steve W
