Multiple user problem -- C# MapScript Web Application (Is
mapserver thread safe?)
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Aug 8 11:42:22 EDT 2006
Tamas,
I have a few applications built with Java mapscript (shape and raster,
so not much really) and they seem to work very well. Years ago (when
mapscript was in its infancy) I performed massive load testing and at
that time I did not experience problems at all.
More recently I have been running the thread test in mapscript/java
against both the standard test map and a map built against oracle
without any problem. Performance was not taken into account, only
correctness.
Umberto
On 8/8/06, Tamas Szekeres <szekerest at gmail.com> wrote:
> Steve,
> As digging into the problem increasingly i am getting more and more
> disappointed. By now i am not sure whether mapscript is safe for
> multithreading at all (even if thread support is switched on).
> For example the most essential gd library uses a number of static
> variables without using any protection when accessing them. The proj
> library also has a number of static variables an we have protection
> only against pj_init in the mapserver code. For example i am
> considering pj_transform is unsafe as well (as using static pj_errno
> for example).
> The problems existing in the libraries cause the same issues as if
> they were in the mapserver code directly. Each of the dll is loaded
> into the process "globally" so any static variable becomes processwide
> global variable.
> Has anyone reviewed the libraries with this regard?
> I have collected the potential problems of the two libraries mentioned
> before. Some of the variables might be const static not causing such
> problems, apologies for those.
> In the gd library:
> gd-2.0.33\gd_gif_in.c(12):static int verbose_set = 0;
> gd-2.0.33\gd_gif_in.c(13):static int verbose;
> gd-2.0.33\gd_gif_in.c(68):} Gif89 = { -1, -1, -1, 0 };
> gd-2.0.33\gd_gif_in.c(244): static unsigned char buf[256];
> gd-2.0.33\gd_gif_in.c(308): static unsigned char buf[280];
> gd-2.0.33\gd_gif_in.c(309): static int curbit,
> lastbit, done, last_byte;
> gd-2.0.33\gd_gif_in.c(360): static int fresh = FALSE;
> gd-2.0.33\gd_gif_in.c(362): static int code_size, set_code_size;
> gd-2.0.33\gd_gif_in.c(363): static int max_code, max_code_size;
> gd-2.0.33\gd_gif_in.c(364): static int firstcode, oldcode;
> gd-2.0.33\gd_gif_in.c(365): static int clear_code, end_code;
> gd-2.0.33\gd_gif_in.c(366): static int table[2][(1<< MAX_LWZ_BITS)];
> gd-2.0.33\gd_gif_in.c(367): static int stack[STACK_SIZE], *sp;
> gd-2.0.33\gd_png.c(50):static jmpbuf_wrapper gdPngJmpbufStruct;
> gd-2.0.33\gdft.c(31):static int fontConfigFlag = 0;
> gd-2.0.33\gdft.c(777):static gdCache_head_t *fontCache;
> gd-2.0.33\gdft.c(778):static FT_Library library;
> gd-2.0.33\gdkanji.c(120): static int whatcode = ASCII;
> gd-2.0.33\gdkanji.c(499): static unsigned char tmp[BUFSIZ];
> gd-2.0.33\gdkanji.c(595): static unsigned char tmp_dest[BUFSIZ];
> In the proj library:
> proj-4.4.9\src\biveval.c(7): static projUV
> proj-4.4.9\src\cs2cs.c(69):static projPJ fromProj, toProj;
> proj-4.4.9\src\cs2cs.c(71):static int
> proj-4.4.9\src\cs2cs.c(76): static char
> proj-4.4.9\src\cs2cs.c(83):static struct FACTORS facs;
> proj-4.4.9\src\cs2cs.c(84):static double (*informat)(const char *,
> proj-4.4.9\src\geod.c(15): static int
> proj-4.4.9\src\geod.c(20): static char
> proj-4.4.9\src\geod.c(129):static char *pargv[MAX_PARGS];
> proj-4.4.9\src\geod.c(130):static int pargc = 0;
> proj-4.4.9\src\geod.c(135): static int eargc = 0, c;
> proj-4.4.9\src\geod_for.c(7): static double
> proj-4.4.9\src\geod_for.c(9): static int
> proj-4.4.9\src\nad2nad.c(16): static int
> proj-4.4.9\src\nad2nad.c(19): static char
> proj-4.4.9\src\nad2nad.c(54):} input = {
> proj-4.4.9\src\nad2nad.c(58):}, output = {
> proj-4.4.9\src\pj_apply_gridshift.c(79): static int debug_count = 0;
> proj-4.4.9\src\pj_gridinfo.c(66):static int byte_order_test = 1;
> proj-4.4.9\src\pj_gridlist.c(50):static PJ_GRIDINFO *grid_list = NULL;
> proj-4.4.9\src\pj_gridlist.c(54):static int last_nadgrids_max = 0;
> proj-4.4.9\src\pj_gridlist.c(55):static int last_nadgrids_count = 0;
> proj-4.4.9\src\pj_gridlist.c(56):static PJ_GRIDINFO **last_nadgrids_list = NULL;
> proj-4.4.9\src\pj_gridlist.c(57):static char *last_nadgrids = NULL;
> proj-4.4.9\src\pj_init.c(71):static paralist *start;
> proj-4.4.9\src\PJ_mod_ster.c(102): static COMPLEX /* Miller Oblated
> Stereographic */
> proj-4.4.9\src\PJ_mod_ster.c(116): static COMPLEX /* Lee Oblated
> Stereographic */
> proj-4.4.9\src\PJ_mod_ster.c(130): static COMPLEX /* 48 United States */
> proj-4.4.9\src\PJ_mod_ster.c(147): static COMPLEX
> proj-4.4.9\src\PJ_mod_ster.c(177): static COMPLEX
> proj-4.4.9\src\PJ_nzmg.c(48): static COMPLEX
> proj-4.4.9\src\PJ_nzmg.c(56): static double
> proj-4.4.9\src\pj_open_lib.c(51):static int path_count = 0;
> proj-4.4.9\src\pj_open_lib.c(52):static char **search_path = NULL;
> proj-4.4.9\src\pj_open_lib.c(53):static char * proj_lib_name =
> proj-4.4.9\src\PJ_robin.c(10):static struct COEFS {
> proj-4.4.9\src\pj_strerrno.c(61): static char note[50];
> proj-4.4.9\src\proj.c(26): static PJ
> proj-4.4.9\src\proj.c(28): static projUV
> proj-4.4.9\src\proj.c(30): static int
> proj-4.4.9\src\proj.c(43): static char
> proj-4.4.9\src\proj.c(49): static struct FACTORS
> proj-4.4.9\src\proj.c(51): static double
> proj-4.4.9\src\rtodms.c(13): static double
> proj-4.4.9\src\rtodms.c(17): static char
> proj-4.4.9\src\rtodms.c(19): static int
> proj-4.4.9\src\pj_datums.c(73):C_NAMESPACE struct PJ_DATUMS pj_datums[] = {
> proj-4.4.9\src\pj_datums.c(98):C_NAMESPACE struct PJ_PRIME_MERIDIANS
> pj_prime_meridians[] = {
> proj-4.4.9\src\pj_ellps.c(8):C_NAMESPACE struct PJ_ELLPS
> proj-4.4.9\src\pj_errno.c(8):C_NAMESPACE int pj_errno = 0;
> proj-4.4.9\src\PJ_goode.c(10): C_NAMESPACE PJ
> proj-4.4.9\src\pj_units.c(10):C_NAMESPACE struct PJ_UNITS
> I wonder if mapscript can safely be used in a real multithreaded
> environment regardless of the performance problems. Are there any
> further experiences about this issue? Which architecture can be used?
> I cannot step beyond the "one process handles one request at a time"
> model.
> Best Regards,
> Tamas
> 2006/8/8, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> > Tamas: What happened to the talk of thread specific globals that
> > was started on mapserver-dev awhile back? Now's the time to move
> > on such things...
> > Steve
> > >>> Tamas Szekeres <szekerest at GMAIL.COM> 8/7/2006 3:22:16 PM >>>
> > Hi,
> > Many of the mapserver components use globally allocated data so
> > multiple threads within the executable (inside libmap.dll in this
> > case) share the same data.
> > Moreover the .dll is loaded into the host application (eg.
> > aspnet_wp.exe or w3wp.exe) and the global variable will be shared
> > among the threads within the overall worker process.
> > The process may host multiple appdomains so the variables is shared
> > among multiple web applications in this case. Lastly, the ASP
> > application model implies the various requests are handled by multiple
> > threads taken out of a pool of threads.
> > It seems terrible compared to the architecture of a windows
> > application, isn't it?
> > If mapserver is compiled with thread support the global data in some
> > of the components are protected by locks to provide synchronized
> > access by multiple threads. The access will take place sequentially so
> > the threads will wait for each
> > other. For example if you are creating mapObj from a .map file
> > multiple requests will wait for each other when parsing the file. This
> > kind of thread interaction may be slightly decreased if the protected
> > critical sections could be made smaller.
> > The issue mentioned previously makes some of us frustrated.
> > Maintaining locks kills the performance of the application, it would
> > be preferable to avoid the global data at all when possible.
> > Unfortunately to achieve this level much of the code should be
> > reconsidered ( a better sort of collaboration should be made between
> > the developers ).
> > I consider this problem is critical and will manifest itself more and
> > more obviously. I wonder the other mapscript languages are living
> > happily without it ;-)
> > Getting back to your question this time i would prefer establishing
> > the mapping functionality in the middleware if possible. The drawing
> > request should be queued and a pool of multiple processes should be
> > spawned to handle the requests. The result may be dispatched back to
> > the client using HTTP. The MONO XSP implementation may also help to
> > establish the required functionality.
> > Best Regards,
> > Tamas Szekeres
> > 2006/8/7, Zhonghai Wang <zhonghaiw at gmail.com>:
> > > Hi All,
> > > I've developed a windows application with the C# MapScript, and this
> > > application works well with all the common mapping functions. I am
> > very
> > > happy with the performance of MapServer. So I am now trying to
> > migrate the
> > > windows application to a web application, here I have some doubts
> > with the
> > > migration:
> > > 1. for the windows application I use a singelton class to return the
> > mapobj
> > > for all the mapping API -- I've programmed a mapping class for
> > mapping
> > > functionalities, and this works well to store all the changes of a
> > mapobj
> > > during the mapping process. But if I migrate the mapping class to
> > web
> > > application, this singelton class should not be used, since there may
> > be
> > > hundred users, who are accessing MapServer at the same time. I am
> > just
> > > wondering how to solve this problem in MapServer?
> > > In MapXtreme, this problem is solved with the use of MapXBroker,
> > which is a
> > > shared pool of MapX objects, does MapServer has any similar
> > component?
> > > 2. Thread-Safety, I know this is not a new question, but it's
> > important. In
> > > the .NET application, how to solve this problem? use thread lock? (I
> > am
> > > programming with VB.NET)
> > > thanks for any information about this topic.
> > > zhonghai
