Removing a directory from CVS...
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Aug 8 16:08:43 EDT 2006
Unfortunately removing directories in one of the things CVS doesn't
support. I think the best we can do is remove all the files inside the dir.
Daniel
Steve Lime wrote:
> Not an ideal solution is it...
> Steve
>>>>"Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 08/07/06 7:22 PM
> See: http://ximbiot.com/cvs/manual/cvs-1.11.22/cvs_7.html#SEC69
> 	-----Original Message-----
> 	From: UMN MapServer Developers List on behalf of Steve Lime
> 	Sent: Mon 07-Aug-06 18:28
> 	To: MAPSERVER-DEV at LISTS.UMN.EDU
> 	Cc:
> 	Subject: [UMN_MAPSERVER-DEV] Removing a directory from CVS...
> 	I probably haven't RTM close enough, but surely this must be
> easy to do.
> 	The gdft directory can be
> 	removed from the repository. It hasn't been used in many
> versions
> 	(probably pre-3.0) and is just
> 	a source of confusion. Anyone know how?
> 	Steve
Daniel Morissette
http://www.mapgears.com/
