Removing a directory from CVS...
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Tue Aug 8 16:22:40 EDT 2006
http://cvsbook.red-bean.com/cvsbook.html#Removing%20Directories
This explains how to do it as best as it can be done.
-Steve W
Daniel Morissette wrote:
> Unfortunately removing directories in one of the things CVS doesn't
> support. I think the best we can do is remove all the files inside the dir.
> Daniel
> Steve Lime wrote:
>> Not an ideal solution is it...
>> Steve
>>>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 08/07/06 7:22 PM
>> See: http://ximbiot.com/cvs/manual/cvs-1.11.22/cvs_7.html#SEC69
>>     -----Original Message-----     From: UMN MapServer Developers List
>> on behalf of Steve Lime     Sent: Mon 07-Aug-06 18:28     To:
>> MAPSERVER-DEV at LISTS.UMN.EDU     Cc:     Subject: [UMN_MAPSERVER-DEV]
>>     I probably haven't RTM close enough, but surely this must be
>> easy to do.
>>     The gdft directory can be
>>     removed from the repository. It hasn't been used in many
>> versions
>>     (probably pre-3.0) and is just
>>     a source of confusion. Anyone know how?
>>     Steve
