PHP/Mapscript still has a memory leak
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Aug 11 09:10:32 EDT 2006
Hi Daniel,
I just updated to mapserver nightly (Aug 9, 2006) and I'm running the
ka-map precache2.php modified to run in apache. The previous fix to
solve the leaking file handles improves things greatly, but there is
still a memory leak.
If I restart apache and fire off the script it uses a modest amount of
memory, under 300MB for the process. Since I'm running 25000 scale, it
runs a long time, and after 24 hours the process is using over 1GB of
memory.
I can send my copy of precache2.php if that would help. The mapfile uses:
OUTPUTFORMAT
NAME PNG8
DRIVER "GD/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGBA
TRANSPARENT OFF
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
I assume this is reproducible with any mapfile. I'll write a bug on this
also.
-Steve
