Bug 1803, Upcoming breaking changes for 4.10.0-beta1
Sean Gillies
sgillies at FRII.COM
Wed Aug 16 18:33:58 EDT 2006
On Aug 16, 2006, at 3:46 PM, Tamas Szekeres wrote:
> Hi All,
> According to the
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1803
> and the agreement on the recent IRC meeting the following object
> members will be marked as immutable on the SWIG interface:
> layerObj.metadata (hashTableObj)
> classObj.label (labelObj)
> classObj.metadata (hashTableObj)
> classObj.layer (layerObj) already marked as immutable in
> mapscript.txt
> fontSetObj.fonts (hashTableObj)
> imageObj.format (outputFormatObj)
> labelPathObj.path (lineObj) missing documentation about
> labelPathObj in mapscript.txt should we expose at all?
> legendObj.label (labelObj)
> legendObj.map (mapObj)
> mapObj.symbolset (symbolSetObj)
> mapObj.fontset (fontSetObj)
> mapObj.labelcache (labelCacheObj)
> mapObj.reference (referenceMapObj)
> mapObj.scalebar (scalebarObj)
> mapObj.legend (legendObj)
> mapObj.querymap (queryMapObj)
> mapObj.web (webObj)
> mapObj.configoptions (hashTableObj)
> webObj.map (mapObj)
> webObj.metadata (hashTableObj)
> Generally there is no need to create these objects externally since
> they have been created internally.
> External creation of these members are unsafe, instead folks should
> work with the already created objects by reading the members mentioned
> above.
> If I get no objections till Aug 17 10:00 (Central European Time) i
> will change map.h and mapscript.txt accordingly so as to get it for
> 4.10.0-beta1.
> Regards,
> Tamas
Tamas,
Don't forget all the colorObjs. Sooner you get word of this to the
user community the better. Despite my warnings and heckling, code
like this
$class->{label} = new mapscript::labelObj;
is very common in user programs.
Sean Gillies
http://zcologia.com
