Connect DODS Server
NicoSIG
nicolasgabarron at YAHOO.FR
Thu Aug 17 05:06:02 EDT 2006
I would like to connect Mapserver to a DODS Server.
latitude and longitude variables must be named 'lat' and 'lon', and on my
Server, they're named 'LATITUDE' and 'LONGUITUDE'.
By using AIS mechanism, I wrote a DAS file with an Alias.
Here is my mapfile:
MAP
CONFIG DODS_AIS_FILE
"/home/alboran/logiciels/apache/htdocs/mtreguer/cartoweb3/projects/sextant_test/server_conf/sextant/dods/ais.xml"
LAYER
NAME "serveur_dods"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"DODS:http://rhsism11.ifremer.fr:8080/dap4cor/dap4cor-coriolis?lat,lon,POSITION_QC&lat>47&lat<50&lon>-6&lon<0"
DATA "location"
STATUS DEFAULT
Here is ais.xml file :
<?xml version="1.0" encoding="US-ASCII" standalone="no"?>
<!DOCTYPE ais SYSTEM "http://xml.opendap.org/ais/ais_database.dtd">
<ais xmlns="http://xml.opendap.org/ais">
<entry>
<primary regexp="http://rhsism11.ifremer.fr:8080/dap4cor*"/>
<ancillary rule="fallback"
url="/home/alboran/logiciels/apache/htdocs/mtreguer/cartoweb3/projects/sextant_test/server_conf/sextant/dods/Coriolis.das"/>
</entry>
</ais>
And this is Coriolis.das:
Attributes {
Alias lat location.LATITUDE;
Alias lon location.LONGITUDE;
but the system return an error:
Error in msOGRFileOpen(): Open failed for OGR connection
`DODS:http://rhsism11.ifremer.fr:8080/dap4cor/dap4cor-coriolis?lat,lon,POSITION_QC&lat>47&lat<50&lon>-6&lon<0'.
Error fetching DAS or DDS:
Error parsing the text on line 1 at or near:
The descriptor object returned from the dataset was null.
Check that the URL is correct.
it seems that aliases are not considered.
how to resolve this problem ??
View this message in context: http://www.nabble.com/Connect-DODS-Server-tf2120281.html#a5847714
Sent from the Mapserver - Dev forum at Nabble.com.
