Connect DODS Server
NicoSIG
nicolasgabarron at YAHOO.FR
Mon Aug 21 03:25:37 EDT 2006
It's OK without DODS_CONF.
My file Coriolis.das was wrong.
If I declare Coriolis.das like that :
Attributes {
ogr_layer_info_1 {
string layer_name toto;
string target_container location.profile;
y_field {
string name location.LATITUDE;
string scope dds;
x_field {
string name location.LONGITUDE;
string scope dds;
This is my dds file :
Dataset {
Sequence {
Float64 TIME;
Float32 TIME_QC;
Float32 LONGITUDE;
Float32 LATITUDE;
Float32 POSITION_QC;
Int32 _id;
Sequence {
Float32 DEPH;
Float32 DEPH_QC;
Float32 PRES;
Float32 PRES_QC;
Float32 TEMP;
Float32 TEMP_QC;
} profile;
Structure {
String PLATFORM_NUMBER;
String PROJECT_NAME;
String PI_NAME;
String DATA_CENTRE;
String DC_REFERENCE;
String DATA_STATE_INDICATOR;
String INST_REFERENCE;
String WMO_INST_TYPE;
String POSITIONING_SYSTEM;
Float64 DATE_UPDATE;
String LIST_PARAM;
} attributes;
} location;
} bathy;
I can access to latitude and longitude variables and profile variables.
but I can't access to attributes variables (attributes is a structure and
not a sequence).
How do I write Coriolis.das to access them ??
Nico
Pericles S. Nacionales-2 wrote:
> Hi!
> I'm no expert on this but I think you also need to define a DODS config
> file
> in your mapfile: CONF DODS_CONF "/path/to/dodsrc"
> The dodsrc file might look something like this:
> # DODS client configuation file. See the DODS
> # users guide for information.
> USE_CACHE=1
> MAX_CACHE_SIZE=50
> MAX_CACHED_OBJ=5
> IGNORE_EXPIRES=0
> CACHE_ROOT=/ms4w/tmp/ms_tmp/dods_cache/
> DEFAULT_EXPIRES=86400
> ALWAYS_VALIDATE=0
> # Request servers compress responses if possible?
> # 1 (yes) or 0 (false).
> DEFLATE=1
> # Proxy configuration:
> # PROXY_SERVER=<protocol>,<host[:port]>
> # PROXY_SERVER=,
> # PROXY_FOR=<regex>,<host[:port]>
> # PROXY_FOR=,
> # NO_PROXY_FOR=<protocol>,<host|domain>
> # NO_PROXY_FOR=,
> AIS_DATABASE=/ms4w/apps/dods_demo/ogr_test_eg.xml
> Lastly, you might need to create a "dods_cache" under your IMAGEPATH.
> Make
> sure the web user has write permission to this directory.
> If all these don't help you, the people who can are probably over at the
> DODS/OPeNDAP forum. If you're not subscribed, go to
> http://www.opendap.org/mailLists/index.html and subscribe to the
> "DODS-TECH"
> mailing list. You might want to search their archive first before sending
> your query.
> Cheers!
> -Perry
> On Thursday 17 August 2006 04:06, NicoSIG wrote:
>> I would like to connect Mapserver to a DODS Server.
>> latitude and longitude variables must be named 'lat' and 'lon', and on my
>> Server, they're named 'LATITUDE' and 'LONGUITUDE'.
>> By using AIS mechanism, I wrote a DAS file with an Alias.
>> Here is my mapfile:
>> MAP
>> CONFIG DODS_AIS_FILE
>> "/home/alboran/logiciels/apache/htdocs/mtreguer/cartoweb3/projects/sextant_
>>test/server_conf/sextant/dods/ais.xml" ...
>> LAYER
>> NAME "serveur_dods"
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> CONNECTION
>> "DODS:http://rhsism11.ifremer.fr:8080/dap4cor/dap4cor-coriolis?lat,lon,POSI
>>TION_QC&lat>47&lat<50&lon>-6&lon<0"
>> DATA "location"
>> STATUS DEFAULT
>> Here is ais.xml file :
>> <?xml version="1.0" encoding="US-ASCII" standalone="no"?>
>> <!DOCTYPE ais SYSTEM "http://xml.opendap.org/ais/ais_database.dtd">
>> <ais xmlns="http://xml.opendap.org/ais">
>> <entry>
>> <primary regexp="http://rhsism11.ifremer.fr:8080/dap4cor*"/>
>> <ancillary rule="fallback"
>> url="/home/alboran/logiciels/apache/htdocs/mtreguer/cartoweb3/projects/sext
>>ant_test/server_conf/sextant/dods/Coriolis.das"/> </entry>
>> </ais>
>> And this is Coriolis.das:
>> Attributes {
>> Alias lat location.LATITUDE;
>> Alias lon location.LONGITUDE;
>> but the system return an error:
>> Error in msOGRFileOpen(): Open failed for OGR connection
>> `DODS:http://rhsism11.ifremer.fr:8080/dap4cor/dap4cor-coriolis?lat,lon,POSI
>>TION_QC&lat>47&lat<50&lon>-6&lon<0'. Error fetching DAS or DDS:
>> Error parsing the text on line 1 at or near:
>> The descriptor object returned from the dataset was null.
>> Check that the URL is correct.
>> it seems that aliases are not considered.
>> how to resolve this problem ??
> Conservation Biology Program
> University of Minnesota
> e-mail: naci0002 at umn.edu
View this message in context: http://www.nabble.com/Connect-DODS-Server-tf2120281.html#a5902291
Sent from the Mapserver - Dev forum at Nabble.com.
