Bug 1803, Upcoming breaking changes for 4.10.0-beta1
Tamas Szekeres
szekerest at GMAIL.COM
Mon Aug 21 06:42:36 EDT 2006
Umberto,
If you are referring to
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1869
it must be noted that this problem applies to *only* RunTimeBuiltWMSClient.java
This one has been using a definitely *defective* way to set the
properties of the web object of the map that is:
web = new webObj();
web.setImagepath("/tmp/");
web.setImageurl("http://katrin/~nicol/mapserver/tmp/");
web.setLog("/tmp/wms.log");
web.setHeader("nh_header.html");
web.setTemplate("../html/form.html");
web.setEmpty("../themen/noFeature.html");
web.setMap(map);
map.setWeb(web);
instead of:
web = map.getWeb();
I would not unwilling to make the software correct instead of blaming
the changes helping these problems to be discovered. You should not
consider if someone has taken away something that was a mistake to
have.
Tamas
2006/8/21, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> Hi all,
> got back today and I have already a bug report because of the changes
> approved in this thread: an API change in 4.10 and probably another in
> 5 is not too respectful of our users I guess.
> Now since the majority of the devs has voted in favour of the proposal
> and I do not have veto rights I'll go on and downgrade the Java
> examples to the newer functionality, but needless to say I'm *very
> disappointed* and I'll consider proposing to make some of these
> changes c-sharp specific since the fatal errors that Tamas seems to
> experience in c-sharp I cannot reproduce them in Java.
> Umberto
> On 8/18/06, Tamas Szekeres <szekerest at gmail.com> wrote:
> > Along with Frank's +1 on the IRC we have at least +3 so i have
> > committed the changes.
> > HISTORY.TXT contains the interface elements affected.
> > /me thinks it was a bit sweaty but was worth the trouble
> > Tamas
> > 2006/8/17, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> > > +1 from me too. The nice thing it's a beta release so there's still time
> > > if we
> > > find we've overstepped a boundary. This is good discussion and I want
> > > to
> > > thank Tamas for the investigative work and solution (and Umberto for
> > > taking
> > > time from vacation - you're more generous than I!)...
> > > Steve
> > > >>> Daniel Morissette <dmorissette at MAPGEARS.COM> 8/17/2006 4:03:53 PM
> > > After a bit more thinking and discussion on IRC, I am with Steve and
> > > also think that all the members that are listed in Steve's email can
> > > safely be made immutable since it would not make sense to attempt to
> > > overwrite them anyway. (That's also the way things are in PHP MapScript
> > > and that never stopped us from doing anything).
> > > With respect to imageObj.format, I think it should be made read-only or
> > > hidden since we get an imageObj from methods that create the actual
> > > image, and changing the outputFormatObj on the image after it's been
> > > created is just asking for trouble (not to mention the possible object
> > > referencing issues that Tamas is trying to address).
> > > I give my +1 to go ahead with this.
> > > Also please make sure you include a note listing the members that were
> > > made immutable in HISTORY.TXT.
> > > Daniel
> > > Steve Lime wrote:
> > > > Umberto: How do you add classes and layers at runtime? In the context
> > > of
> > > > a layer or a map
> > > > correct? I don't believe that what Tamas is proposing would change
> > > that
> > > > capability at all.
> > > > If you look at the list:
> > > > classObj.layer
> > > > webObj.map
> > > > legendObj.map
> > > > layerObj.map
> > > > are back references and you don't want folks monkeying around with
> > > > them.
> > > > classObj.label
> > > > legendObj.label
> > > > mapObj.scalebar
> > > > mapObj.legend
> > > > mapObj.querymap
> > > > mapObj.web
> > > > mapObj.symbolset
> > > > mapObj.labelcache
> > > > mapObj.reference
> > > > Already exist in their parent objects so there is no need to create
> > > new
> > > > ones in place of the
> > > > existing ones. Users should get the reference to the existing
> > > structure
> > > > and modify it in place.
> > > > I'm not sure that given the potential problems that it even makes
> > > sense
> > > > to have constructors
> > > > for these. I assume this is the contentious spot...
> > > > (If there is a glaring need to have, for example, an unattached
> > > > labelObj laying around then
> > > > couldn't a populateFrom capability be developed for a labelObj, or
> > > > perhaps setLabel() for a
> > > > classObj?)
> > > > classObj.metadata
> > > > fontSetObj.fonts
> > > > mapObj.configoptions
> > > > webObj.metadata
> > > > Are hash tables and Sean created a nice interface for them to use.
> > > > Modifying directly shouldn't
> > > > be allowed. I think this is what was ok'd yesterday.
> > > > Note sure about imageObj.format...
> > > > I guess I don't see the big deal with this change. My 2 cents.
> > > > Steve
> > > >>>>Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 8/17/2006 8:25 AM
> > > > On 8/17/06, Daniel Morissette <dmorissette at mapgears.com> wrote:
> > > >>Tamas Szekeres wrote:
> > > >>>>I think you can safely hide the labelPathObj, that should not be
> > > >>>>exposed. I think the others
> > > >>>>should be immutable too (assuming I understand the problem
> > > > correctly),
> > > >>>>the question is how
> > > >>>>many scripts will the change break and should backward
> > > > compatability
> > > >>>>breakage be limited
> > > >>>>to major releases (e.g. 5.0).
> > > >>>Those scripts are *erroneous* ! It would be desirable to force
> > > > the
> > > >>>users to put them into a good shape as soon as possible.
> > > >>It seems that I should take position as release manager but
> > > >>unfortunately I do not know or use SWIG MapScript much so I have to
> > > > rely
> > > >>on those who know to make an opinion on whether the current stuff is
> > > >>dangerous enough to warrant breaking a few scripts with 4.10.
> > > >>Based on the understanding I have of the problem from reading this
> > > >>thread and previous discussions, it seems to me that if those
> > > > scripts
> > > >>are doing something that is just waiting to bomb then changing SWIG
> > > >>MapScript in v4.10 to make those object references immutable is not
> > > > a
> > > >>backwards compatibility issue, it is a bugfix and a service we are
> > > >>making to those users by forcing them to fix their scripts... and in
> > > > the
> > > >>end their apps will just be more robust.
> > > > Daniel,
> > > > IMO we are talking about fixing pieces of code we are not even sure
> > > > they are broken. For instance I have some Java mapscript tests (and
> > > an
> > > > application) running just fine that add layers and classes at run
> > > time
> > > > and that's why I am so reluctant in approving this proposal. Only
> > > once
> > > > we get a test case that reproduces this errors reliably then we can
> > > go
> > > > and change the code.
> > > > Unfortunately I couldn't join the IRC meeting because I am on
> > > vacation
> > > > otherwise I'd have spoken earlier (I am writing this on the road).
> > > > Regards,
> > > > Umberto
> > > >>The real question that I would throw at the SWIG MapScript experts
> > > > is:
> > > >>"Is the practice of overwriting those object references really
> > > > dangerous
> > > >>or not?"
> > > >>If the answer is yes then I think that solves the question and we
> > > > need
> > > >>to apply the fix and force users to fix their scripts.
> > > >>If there are object references that can safely be overwritten (such
> > > > as
> > > >>colorObj) then my opinion is that we should not touch them in 4.10.
> > > >>Daniel
> > > >>Daniel Morissette
> > > >>http://www.mapgears.com/
> > > Daniel Morissette
