Missing elements in the SWIG interface documentation
Tamas Szekeres szekerest at GMAIL.COM
Sat Aug 26 18:47:30 EDT 2006
Developers,
After comparing the SWIG interface and the corresponding documentation
the following elements are missing and should be updated in the doc.
I'm considering some of the interface elements are not to be exposed at all.
1. Missing interface elements
1.1 constants:
int MAX_ERROR_LEN
int MS_MAXCLASSES
int MS_MAXSTYLES
int MS_MAXLAYERS
int MS_POSITIONS_LENGTH
int MS_SHP_POINTZ
int MS_SHP_ARCZ
int MS_SHP_POLYGONZ
int MS_SHP_MULTIPOINTZ
int MS_GEOSERR
int MS_RECTERR
int MS_TIMEERR
int MS_GMLERR
int MS_SOSERR
int MS_HASHSIZE
int MAX_PARAMS
1.2 enums:
Some of the constants are exposed as enumerations missing from the documentation
1.3 functions:
public static void msConnPoolCloseUnreferenced();
public static void msFreeImage(imageObj img);
public static errorObj msGetErrorObj();
public static string msGetErrorString(string delimiter);
public static string msGetVersion();
public static void msResetErrorList();
mapscript.msSaveImage(mapObj, imageObj, String) : Int32
mapscript.msSetup() : Int32
1.4 classes:
DBFFieldType class
DBFInfo class
imageObj.getBytes()
intarray.cast()
intarray.frompointer(int*)
intarray.getItem(int)
intarray.setItem(int, int)
labelCacheMemberObj.labelpath
labelCacheObj.labels
labelObj.autofollow
labelObj.encoding
layerObj.labelangleitemindex
layerObj.labelitemindex
layerObj.labelsizeitemindex
layerObj.plugin_library
layerObj.plugin_library_original
layerObj.getProjection()
layerObj.setProcessing(string)
layerObj.whichShapes(rectObj)
lineObj.point
mapObj.layerorder
mapObj.outputformatlist
mapObj.saved_extent
mapObj.getNumSymbols()
markerCacheMemberObj class
outputFormatObj.formatoptions
outputFormatObj.inmapfile
outputFormatObj.numformatoptions
outputFormatObj.refcount
OWSRequest.contenttype
queryMapObj class
rectObj.fit(int,int)
shapefileObj.isopen
shapefileObj.lastshape
shapefileObj.source
shapefileObj.status
shapefileObj.statusbounds
shapefileObj.addPoint(pointObj)
shapefileObj.getExtent(int, rectObj)
shapefileObj.getPoint(int, pointObj)
shapefileObj.getTransformed(mapObj, int, shapeObj)
shapeObj.geometry
shapeObj.line
shapeObj.clone()
styleObj.angle
styleObj.angleitem
styleObj.antialias
styleObj.maxcolor
styleObj.maxvalue
styleObj.maxwidth
styleObj.mincolor
styleObj.minwidth
styleObj.rangeitem
styleObj.rangeitemindex
styleObj.sizeitem
styleObj.width
symbolObj.style
symbolObj.setImagepath(string)
symbolSetObj.imagecachesize
symbolSetObj.symbol
webObj.browseformat
webObj.legendformat
2. TODOs
classObj.keyimage
imageObj.size
labelCacheMemberObj.featuresize
labelCacheMemberObj.styles
labelCacheObj.cachesize
labelCacheObj.markercachesize
labelObj.angle
layerObj.footer
layerObj.header
layerObj.addFeature(shapeObj)
layerObj.draw(mapObj, imageObj)
layerObj.getNumFeatures
mapObj.datapattern
mapObj.maxsize
mapObj.querymap
mapObj.templatepattern
mapObj.prepareQuery()
OWSRequest.postrequest
shapeObj.setBounds
symbolObj.gap
symbolObj.linecap
symbolObj.linejoin
symbolObj.linejoinmaxsize
symbolObj.position
symbolObj.sizex
symbolObj.sizey
symbolObj.transparent
symbolObj.transparentcolor
webObj.empty
webObj.error
webObj.log
webObj.maxtemplate
webObj.mintemplate
webObj.queryformat
Let us decide what to do with these elements. I think can document
some of them but other volunteers should also be needed.
\mapscript\doc\mapscript.txt should always be the most recent version.
The class members should be placed into the documentation in alphabetical order.
Tamas
