--enable-coverage
Howard Butler
hobu at IASTATE.EDU
Mon Aug 28 09:54:11 EDT 2006
Daniel,
mpatrol is gone
<http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1883>. I guess I
was antsy to get rid of it :)
If we keep the --enable-coverage option, I would like to see it
renamed if at all possible. Maybe --enable-coverage-testing or
something like that. It's just too easy to see that and go, "gee,
that must be how I turn on ArcInfo coverage support" for our
GIS-familiar users.
I still wonder though, is anyone using --enable-coverage, and if so,
how do you use it?
Howard
At 9:42 AM -0400 8/28/06, Daniel Morissette wrote:
>Howard Butler wrote:
>>Going through the Unix Compilation HOWTO, I noticed a comment at
>>the bottom of the document complaining about confusion about this
>>configure command. Is anyone using it anymore? Hasn't Valgrind
>>made Mpatrol obsolete? Can we ditch it for 4.10?
>>Howard
>I'm not sure who added this option to the configure.in script, but
>it seems to be there to track code coverage and would be unrelated
>to using mpatrol/valgrind, so I think it needs to stay there,
>perhaps just with an explanation that these options are for
>profiling and if one doesn't know what that means then they should
>not use them:
>dnl ---------------------------------------------------------------------
>dnl Enable source code coverage reporting for GCC
>AC_ARG_ENABLE(coverage,
>[ --enable-coverage Enable coverage testing],
>[CFLAGS="$CFLAGS -fprofile-arcs -ftest-coverage"])
>With respect to ditching Mpatrol-related stuff, I only use Valgrind
>myself and would have no objection to seeing the Mpatrol stuff
>removed. Does anyone use Mpatrol?
>Daniel
>Daniel Morissette
>http://www.mapgears.com/
