Mapserver compilation flags should be added to the SWIG
command line
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Aug 28 11:21:41 EDT 2006
Tamas Szekeres wrote:
> Folks,
> Currently most of the SWIG bindings does not add mapserver compilation
> flags to the
> SWIG command line and therefore the interface might not be generated
> properly.
> For example missing -DUSE_POINT_Z_M will prevent from generating z and m
> members
> for pointObj etc.
> I've added a bug for this issue:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1881
> And fixed for C#
Does something need to be done for this for the other wrappers? There
used to be a 'mapscriptvars' file with all the compile flags used by the
Perl Makefile. Is this not used by the other bindings?
Daniel
Daniel Morissette
http://www.mapgears.com/
