MSAutotest WxS on windows
Normand Savard
nsavard at MAPGEARS.COM
Mon Aug 28 15:19:12 EDT 2006
Frank Warmerdam wrote:
> Folks,
> In the IRC meeting today I agreed to try and get the MSAutotest
> WxS tests working roughly on windows. I dug into the problems and it
> turned out the main issue was with quoting of the command lines. It
> was done like this:
> # RUN_PARMS: wcs_cap.xml [MAPSERV]
> QUERY_STRING='map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities'
> > [RESULT_DEVERSION]
> But for windows needed to use double quotes instead of single quotes:
> QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities"
> > [RESULT_DEVERSION]
> I have applied this to all wxs/*.map files except for wfs_filter.map
> which
> includes some double quotes in the query string. This one will require
> greater care I think, likely changing the internal double quotes into
> whatever
> the proper url escape sequence for " is.
I url encoded double quotation in query_string found in wms_sld.map and
wfs_filter.map.
> I also fixed some problems with CRLF conversion. The templates were in
> DOS format but this was getting wiped in some circumstances resulting in
> comparison failures. I just "upgraded" all files to unix text
> conventions.
> There are still some errors, but I'll turn that over to Bart (and perhaps
> Norm or others interested) including:
> o New "version" keyword in gml3l0 output.
I'll check in the specification if this new keyword is described and if
yes I will update the expected result. Is there any other solution?
> o windows does expoential notation with three digits instead of two.
I think we have no choice here to have two sets of expected results:
one for Windows and one for Unix. Unless we use an external program
that will compare files and check for numbers precisions like ndiff.
> o some maps now emit error comments.
I solved one of them: wfs_simple.map (bug MS1413).
