Fix for bug #1629
Fernando Simon
fsimon at UNIVALI.BR
Wed Feb 1 06:23:48 EST 2006
Hi Umberto,
For Oracle Spatial connection I'm working to solve a problem with
query modes and filters that Prema reported.
It's related with Filter/FilterItem and query (itemquery/itemnquery)
mode. I didn't open a bug report in bugzilla because I didn't have time
to write a good report, so it's my fault.
Best regards.
Fernando Simon
Umberto Nicoletti wrote:
> I have checked out HEAD and verified on a map of my own the the bug
> exists by defining both FILTER and FILTERITEM on a layer. If I removed
> the FILTERITEM then the map worked again as expected.
> Then I have applied my patch and verified that the map worked again with:
> -both FILTER and FILTERITEM
> -only with FILTER
> -only with FILTERITEM
> I used the following values in the test:
> FILTER = ' myattribute=A OR myattribute=B '
> FILTERITEM='myattribute'
> Last but not least I checked the Oracle spatial code and can confirm
> (If I understood correctly) that the behaviour of postgis with my
> patch matches that of Oracle Spatial, that is the FILTERITEM is
> ignored (as the docs say).
> To be frank I have not tested using msSearchByAttribute because that
> would have required some more time (which I really do not have) but
> for what I know they should end up calling the same functions, so the
> tests are to be considered valid.
> I hope this answers your question.
> Note 1: we should really set up some automated tests for stuff like
> this and in particular for regression testing and integrate them in
> the build process.
> Note 2: I think that we should delay 4.8: better late but working than
> in time but with errors.
> Best Regards,
> Umberto
> On 1/31/06, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
>> How confident are you that this is a safe change to make? Is there any
>> potential for side-effects?
>> How'bout we keep this in CVS head for now and include it only in 4.8.1
>> in a couple of weeks once we are confident that the CVS head changes
>> have been well tested and are safe to backport? I would hate to see
>> 4.8.0 delayed again because of a last minute bug.
>> Talking about 4.8.0, can we release it later this week, let's say Thursday?
>> Daniel
>>> It's in cvs head.
>>> Umberto
>>> On 1/31/06, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
>>>> I guess I'd say CVS head and see if we can get a few folks to test. Then backport upon confirmation. If that confirmation can happen quickly then including in 4.8 is ok with me.
>>>> Steve
>>>>>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/30/06 9:53 AM >>>
>>>> I am working on a patch for bug #1629. Shall I commit to HEAD or the
>>>> latest 4.8 rc?
>>>> I attach the patch in case comeone wants to give it a try (I already
>>>> did, anyway).
>>>> Regards,
>>>> Umberto
>> Daniel Morissette dmorissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
