CVS error
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Feb 7 09:26:50 EST 2006
Oops, sorry about that. I'll take care of that this morning.
Steve
>>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 02/07/06 7:56 AM >>>
Kralidis,Tom [Burlington] wrote:
> In file included from map.h:2068,
> from mapogr.cpp:137:
> mapows.h:379: error: syntax error before `template'
> make: *** [mapogr.o] Error 1
This is a problem that we had encountered a while ago with all the other
instances of "template" in C structs, when used in a C++ file since
template is a reserved keyword in C++.
The solution that we had implemented everywhere else and that I applied
to mapows.h is to use _template in C++:
#ifndef __cplusplus
char *template;
#else
char *_template;
#endif
Steve: since this is a new object that you just added, if you could use
something other than template then that might be ever better.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
