A Windows Build Tree for MapServer
Howard Butler
hobu at IASTATE.EDU
Wed Feb 8 12:42:45 EST 2006
I don't know anything about PHP yet. I was going to attempt to
incorporate that in there, but I need to work with Assefa to do it.
I would make all this available as a big zip file (emphasis on big).
BTW, all of the mapscript tests pass with this configuration (dynamic
everything).
At 11:40 AM 2/8/2006, Bart van den Eijnden (OSGIS) wrote:
>Hi Howard,
>sounds interesting! I tried to use relative paths once but never got
>everything to work that way.
>I am missing PHP/Mapscript though in your bin output dir.
>Is there an archive we can download to test this?
>Best regards,
>Bart
>Howard Butler wrote:
>>All,
>>Assefa and I have been collaborating on a unified build tree for
>>Windows binaries for MapServer. This is a note to tell you what
>>has been done so far and to propose some changes to the nmake.opt
>>and makefile.vc files to streamline our build process a little bit
>>and make it work nicely with the build tree.
>>Building MapServer on Windows is a major PITA. I have maintained
>>something called the "kitchen sink," Assefa has maintained MS4W and
>>PHP MapScript, and Perry also has a binary set. I would like to
>>try to collect things together a bit so they all build off of
>>common stuff. The reasoning behind this is to make it a bit easier
>>for folks to swap libmap.dlls to get functionality from one build
>>or another (mostly thinking of SDE, Oracle, and MrSID) into various
>>.exe and MapScripts. I do not know whether or not this dream is
>>realistic or not.
>>In any case, I have been working on a build tree at
>><http://hobu.stat.iastate.edu/mapserver/build_output/assefa>. It
>>contains almost everything for a full GDAL and MapServer build.
>>Everything has been brought up to date. Everything has been built
>>dynamically with /MD. GDAL is built with plugins for SDE, Oracle,
>>and MrSID. The intent is for someone wishing to build their own
>>MapServer to just grab the build tree, tweak nmake.opt to give the
>>path to it and do nmake /f makefile.vc and have it build up
>>everything all at once. This is with MSVC 7.1, so it obviously
>>isn't for everyone, but I think it could go a long way in making it
>>much easier for folks to build things without having to worry about
>>the bazillions of little issues that crop up along the way.
>>To make this work, I have done some slight modifications to the
>>nmake.opt and makefile.vc files. These include setting things up
>>to use relative paths, and creating install targets for the
>>mapscripts and .exe/.dll so they are collated into the ../bin
>>directory. I would like to go through nmake.opt and make some
>>changes to make things be relative to this build tree. I would
>>also add some things like SWIG and JAVA_HOME to make it easier to
>>have MapScript build targets. I would make these changes in CVS
>>HEAD. I would also create/edit the Win32 build HowTo to describe
>>how to use this.
>>If people want to me to write an RFC to describe this stuff I can do so.
>>As an aside, I would really like to reconfigure Oracle and SDE to
>>use the plugin architecture. They seem to cause no end of requests.
>>Using plugins for these should make our build layout/setup much
>>easier. I plan on pursuing this for the Hawaii 5-0 release.
>>Howard
>OSGIS, Open Source GIS
>http://www.osgis.nl
