A Windows Build Tree for MapServer
Howard Butler
hobu at IASTATE.EDU
Wed Feb 8 14:25:45 EST 2006
At 01:10 PM 2/8/2006, Jani Averbach wrote:
> > -----Original Message-----
> > From: UMN MapServer Developers List On Behalf Of Howard Butler
> > Sent: Wednesday, February 08, 2006 10:03 AM
> > Subject: A Windows Build Tree for MapServer
> > Assefa and I have been collaborating on a unified build tree for
> > Windows binaries for MapServer. This is a note to tell you what has
> > been done so far and to propose some changes to the nmake.opt and
> > makefile.vc files to streamline our build process a little bit and
> > make it work nicely with the build tree.
>This is a great news!
> > In any case, I have been working on a build tree at
> > <http://hobu.stat.iastate.edu/mapserver/build_output/assefa>. It
> > contains almost everything for a full GDAL and MapServer
> > build. Everything has been brought up to date. Everything has been
> > built dynamically with /MD. GDAL is built with plugins for SDE,
> > Oracle, and MrSID. The intent is for someone wishing to build their
> > own MapServer to just grab the build tree, tweak nmake.opt to give
> > the path to it and do nmake /f makefile.vc and have it build up
> > everything all at once. This is with MSVC 7.1, so it obviously isn't
> > for everyone, but I think it could go a long way in making it much
> > easier for folks to build things without having to worry about the
> > bazillions of little issues that crop up along the way.
>I would like to take this a little bit further and propose that we use
>VC project files instead of makefiles. This would make it easier to
>work with mapserver code base on windows and solve few problems with
>GDAL. If you build GDAL with debugging (/MDd) and later turn the
>project to release mode (/MD) then you have very high changes to blow
>up the binary because the makefile system will mix debug and release
>mode binaries very easily.
I am a firm -1 against project files. Granted they aren't as bad in
msvc7+, but they still can cause a lot of grief. I especially have
trouble navigating the myriad of menus to figure out where to add lib
files, etc.
I understand the runtime issues (/MD vs /MDd), but usually the
compiler complains about needing NODEFAULTLIB which is a tip that you
have things mixed up.
GDAL and MapServer have long histories of nmake makefiles
(recursively, even), and those who maintain the software are not apt
to change this, I think. Another issue MapServer has is
bison/flex/yacc-generated files, which cause complications as
well. Coupled with the fact that it is impossible to debug how a
user is running a project file over email "no, click on the thing
next to the other thingy in the option menu that you have to remember
to enable", I don't see us changing at this time.
I like debugging in the IDE as much as the next person. Getting the
Windows builds to even use the same compiler options and layout
is/has been a challenge. Building MapServer on Windows used to be
only for the most courageous, and I'm hoping to lower that bar. I'm
not ready to ditch the makefiles though.
Howard
