4.10/5.0 Roadmap?
Jerry Pisk jerry.pisk at GMAIL.COM
Wed Feb 15 19:58:45 EST 2006
Hello,
I was looking at this and come to the following:
msLayerGetShape takes two parameters ot identify a shape, a tile and a
record number. If those numbers do not have to uniquely identify a
specific shape across msLayerOpen and msLayerClose calls then this is
going to be a trivial issue to solve, at least for the PostGIS layer
data type. However, talking to FrankW on IRC I am not sure that this
is a safe assumption to make, he mentioned this causing problems in
some usage scenarios. I would appreciate if someone could shed more
light on this.
Regards,
Jerry Pisk
On 2/1/06, Fernando Simon <fsimon at univali.br> wrote:
> Hi all,
>    I have just a little issue for the query support in Mapserver.
>    It's about the way how Mapserver execute a query (query modes, using
> itemnquery as example) in databases (Oracle Spatial/PostGIS), One
> function/query to return just the ID for the row and another function
> (with the same Select) to return the data from the table. I already
> exposed to Daniel and Frank the problem and I hope that they have more
> comments about it.
>    I believe that this issue can be add in the list for the next
> release, and will be a good improvement.
>    Best regards.
> Fernando Simon
