RFC 11: Curved Labels
Pericles S. Nacionales
naci0002 at UMN.EDU
Thu Feb 16 14:30:54 EST 2006
+1 for me as well and I agree with Daniel--ANGLE FOLLOWPATH makes more
sense to me.
-Perry
Daniel Morissette wrote:
> Steve Lime wrote:
>> Hi all: You may or may not know that a patch for curved label support
>> just mysteriously appeared one morning a bit ago in bugzilla. Output
>> is pretty impressive. I worked with the author on a few integration
>> points (collision avoidance being the biggie) and an patched patch was
>> submitted in the last week. (Thanks Benj!)
>> Anyway, we wrote up a quick RFC for your consideration. See:
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-11
> I'm ready to say +1, but just a quick comment about "ANGLE FOLLOW" in
> the mapfile... follow what? Should we use "ANGLE FOLLOWPATH" instead?
> Also, what if we ever implement more advanced or more expensive
> algorithms later, for instance options to try different label positions
> in case of collisions, that would be more computationally expensive and
> we might not want to enable that by default so we'd need more mapfile
> options to control that. As we define a name for this new feature in the
> mapfile, should we plan for a way to name multiple algorithms or options
> in the future?
> I guess I'm just thinking outloud... "ANGLE FOLLOW" (or FOLLOWPATH)
> could be fine for now and we can deprecate it later if we add more
> advanced options. At that point we will better know which kind of
> options we would need anyway.
> Daniel
