RFC 11: Curved Labels
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Feb 16 22:37:07 EST 2006
>>>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 02/16/06 1:12 PM >>>
> Steve Lime wrote:
>> Hi all: You may or may not know that a patch for curved label support just
>> mysteriously appeared one morning a bit ago in bugzilla. Output is pretty
>> impressive. I worked with the author on a few integration points (collision
>> avoidance being the biggie) and an patched patch was submitted in the last
>> week. (Thanks Benj!)
>> Anyway, we wrote up a quick RFC for your consideration. See:
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-11
> I'm ready to say +1, but just a quick comment about "ANGLE FOLLOW" in
> the mapfile... follow what? Should we use "ANGLE FOLLOWPATH" instead?
I still like FOLLOW for a couple of reasons:
1) what else could it mean? (PATH is redundant)
2) I like to keep the keyword set small and FOLLOW might have uses else where in the future
> Also, what if we ever implement more advanced or more expensive
> algorithms later, for instance options to try different label positions
> in case of collisions, that would be more computationally expensive and
> we might not want to enable that by default so we'd need more mapfile
> options to control that. As we define a name for this new feature in the
> mapfile, should we plan for a way to name multiple algorithms or options
> in the future?
It's hard to envision what those might be. I think we need to be able to
play with this new code and then tweak things if necessary. It's only the
development version so there is time.
I think for positioning we have enough parameters at the moment.
> I guess I'm just thinking outloud... "ANGLE FOLLOW" (or FOLLOWPATH)
> could be fine for now and we can deprecate it later if we add more
> advanced options. At that point we will better know which kind of
> options we would need anyway.
> Daniel
Steve
