latest CVS build warnings
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Feb 17 13:39:18 EST 2006
Build env: FC4.
$ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --with-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=/usr/local/src/php/php-5.1.2 --with-ming=/usr/local
Errors:
mapxbase.c: In function �msDBFReadAttribute’:
mapxbase.c:524: warning: pointer targets in passing argument 2 of �__builtin_strncpy’ differ in signedness
mapsymbol.c: In function �msRotateSymbol’:
mapsymbol.c:1223: warning: unused variable �color’
mapraster.c: In function �msDrawRasterLayerLow’:
mapraster.c:1375: warning: comparisons like X<=Y<=Z do not have their mathematical meaning
mapogr.cpp: In function �int msOGRLayerGetAutoStyle(mapObj*, layerObj*, classObj*, int, long int)’:
mapogr.cpp:2185: warning: �oPenColor$red’ may be used uninitialized in this function
mapogr.cpp:2185: warning: �oPenColor$green’ may be used uninitialized in this function
mapogr.cpp:2185: warning: �oPenColor$blue’ may be used uninitialized in this function
mapogr.cpp:2185: warning: �oPenColor$pen’ may be used uninitialized in this function
maplayer.c: In function �msINLINELayerGetShape’:
maplayer.c:1256: warning: statement with no effect
mapdraw.c: In function �msDrawMap’:
mapdraw.c:467: warning: implicit declaration of function �msDrawWMSLayerSWF’
mapdraw.c:474: warning: implicit declaration of function �msDrawWMSLayerPDF’
mapgd.c: In function �msDrawTextGD’:
mapgd.c:3061: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3062: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3063: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3064: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3065: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3066: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3067: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3068: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3072: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3074: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3084: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3085: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3086: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3087: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3088: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3089: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3090: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3091: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3095: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapgd.c:3097: warning: pointer targets in passing argument 5 of �gdImageString’ differ in signedness
mapswf.c: In function �BuildButtonFromGD’:
mapswf.c:513: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �BuildEllipseButton’:
mapswf.c:598: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:603: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �BuildButtonPolygon’:
mapswf.c:789: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:796: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:800: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �BuildButtonLine’:
mapswf.c:851: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:857: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �msImageStartLayerSWF’:
mapswf.c:1047: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1051: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1057: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1062: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawStartShapeSWF’:
mapswf.c:1133: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1141: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawMarkerSymbolSWF’:
mapswf.c:1342: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1361: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1388: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1426: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1440: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1479: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1502: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �DrawButtonFilledPolygon’:
mapswf.c:1582: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:1589: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:1593: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �DrawButtonPolyline’:
mapswf.c:1618: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c:1623: warning: passing argument 2 of �SWFButton_addShape’ from incompatible pointer type
mapswf.c: In function �msDrawLineSymbolSWF’:
mapswf.c:1781: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1788: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawShadeSymbolSWF’:
mapswf.c:1918: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1925: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1963: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:1970: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �draw_textSWF’:
mapswf.c:2088: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawLabelCacheSWF’:
mapswf.c:2250: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawWMSLayerSWF’:
mapswf.c:2636: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawRasterLayerSWF’:
mapswf.c:2690: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msSaveImageSWF’:
mapswf.c:2838: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2842: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2846: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2851: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2859: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2864: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2869: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2876: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2981: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:2997: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:3003: warning: too few arguments for format
mapswf.c:3006: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c:3012: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mapswf.c: In function �msDrawVectorLayerAsRasterSWF’:
mapswf.c:3170: warning: passing argument 2 of �SWFMovie_add’ from incompatible pointer type
mappdf.c: In function �msDrawTextPDF’:
mappdf.c:1436: warning: assignment makes integer from pointer without a cast
mapogcsld.c: In function �msSLDGetAttributeNameOrValue’:
mapogcsld.c:4124: warning: �szCompare[0]’ may be used uninitialized in this function
mapogcsld.c:4124: warning: �szCompare[1]’ may be used uninitialized in this function
mapogcsld.c:4125: warning: �szCompare2[0]’ may be used uninitialized in this function
mapogcsld.c:4125: warning: �szCompare2[1]’ may be used uninitialized in this function
maptime.c: In function �msStrptime’:
maptime.c:169: warning: implicit declaration of function �strptime’
maptime.c:169: warning: return makes pointer from integer without a cast
cgiutil.c: In function �loadParams’:
cgiutil.c:136: warning: suggest parentheses around assignment used as truth value
epplib.c: In function �position’:
epplib.c:231: warning: pointer targets in passing argument 1 of �swap2’ differ in signedness
