RFC 12
Sean Gillies
sgillies at FRII.COM
Sat Feb 18 16:34:40 EST 2006
Umberto,
I think you will have to remove the language about test driven
development from RFC 12. It's a distraction from your main
proposition: that C unit tests will be good for MapServer.
I myself am game to help you out with C unit tests. However, it's no
use trying to mandate that people use them. MapServer just doesn't
have a culture of testing, and that's all there is to it.
All we can do is write them, use them, encourage others to do so, and
apply a little (friendly) shaming on people who write code that
breaks them :) If the tests are easy to run, and useful, there's a
good chance that developers will grab onto them, but that's the best
you're going to get.
So, trim the RFC, and let's see a first good example of using cunit.
I'd like to see if it could replace much of the Python mapscript test
suite.
cheers,
Sean
