extended version information from Mapserver
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Feb 23 11:18:05 EST 2006
This is a good idea. I think it would be nice to do for all libs
MapServer has been built with (i.e. name/version).
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Brent Fraser
> Sent: Thursday, February 23, 2006 11:06 AM
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-DEV] extended version information
> from Mapserver
> Frank,
> One of the posts to the Mapserver Users list last nite
> involved a question about how to get ECW files working with
> Mapserver. It would be nice to have a way to check the
> capabilities of the GDAL (and other options?) linked to
> MapServer. Last month I had a similar need and wrote a
> function (for v4.8) to include in maperror.c:
> /* Detailed information about the various options
> compiled in: */
> ------ */ char *msGetVersionDetailed() {
> static char version[2048];
> long iDr=0;
> strcat(version, "Version Details:\n");
> #ifdef USE_GDAL
> strcat(version, " " );
> strcat(version, GDALVersionInfo( "--version" ) );
> strcat(version, ":\n" );
> GDALAllRegister();
> for( iDr = 0; iDr < GDALGetDriverCount(); iDr++ )
> GDALDriverH hDriver = GDALGetDriver(iDr);
> strcat(version, GDALGetDriverShortName( hDriver ) );
> strcat(version, ": ");
> strcat(version, GDALGetDriverLongName( hDriver ) );
> strcat(version, "\n" );
> GDALDestroyDriverManager();
> #endif
> return(version);
> I also added (to my version only) a new command line
> parameter to the arg processing of mapserv.c:
> if( strcmp(argv[iArg],"-d") == 0 ) {
> printf("%s\n", msGetVersionDetailed());
> fflush(stdout);
> exit(0);
> This would prevent the "details" from being written to every
> web page as the "-v" results are now.
> So now the questions:
> 1. Could you check the code in (if you think it's
> reasonable)? I'll file a bug report to track the change. 2.
> Are there any immediate ramifications with respect to the
> plug-in architecture (RFC 8)?
> Thanks!
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
