OracleSpatial QueryAttribute
Hallgren Johan E
jhhal at WMDATA.COM
Fri Feb 24 04:50:20 EST 2006
Hello,
No I have tried the OracleSpatial Native support. Everything works fine
until I try to queryAttributes.
I don't get the expected results but I can se that the following SQL is
sent to Oracle.:
SELECT OBJECTID, , shape FROM (SELECT objectid, shape, fnr_fds FROM
bergvikmark_sdo) WHERE FNR_FDS = '200205688' AND SDO_FILTER(
shape, MDSYS.SDO_GEOMETRY(2003, NULL,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(70420.
8121,6043080.13,3097864.19,7727610.88) ),'querytype=window') = 'TRUE'
As I can see the problem is in the beginning, "SELECT OBJECTID, ,". I
tried to look at the code and in maporaclespatial.c/
msOracleSpatialLayerWhichShapes() (I think that's functions is used)
I don't understand what's wrong...
I'm using mapserver-4.8.1
Oracle 10.1 (windows Server)
I'm using the MapScript api.
MapFile:
CONNECTION "wmgis/xxx at wmsi1394"
CONNECTIONTYPE oraclespatial
DATA "shape FROM (SELECT objectid, shape, fnr_fds FROM bergvikmark_sdo)
USING UNIQUE OBJECTID VERSION 10g"
I have also tried the
DATA "shape FROM bergvikmark_sdo USING UNIQUE OBJECTID VERSION 10g"
But the same result.
Any ideas?
/Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-844 65 (int: +46-2384465)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se <BLOCKED::http://www.wmdata.se>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060224/7d48fd3a/attachment.html
