RFC 13 : SOS support
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Fri Feb 24 14:23:25 EST 2006
Yewondwossen Assefa wrote:
> Hi all,
>   As mentionned a few weeks ago on the list, we were working on trying
> to  have an SOS support in Mpaserver using the same concepts applied for
> wms/wfs/wcs.  There is an RFC explaining more on what the intentions
> are.  Could you please have a look and give feed backs if possiible.
>  Thanks
>    http://mapserver.gis.umn.edu/development/rfc/ms-rfc-13
In the RFC, you wrote:
> In Mapserver an Offering will be represented by a group of layers using
> a metadata to group those layers.
Would it have made sense to use the layer's group variable as the group
id instead of a metadata for the grouping?
I presume the other metadata for the group (name and description) will
be taken from the first layer in a given group in the mapfile, the same
way that this currently works for grouped WMS layers. Should this be
specified?
It's rare that this happens, I usually have good opinions on things, but
in this case I can't make my mind on whether this should be integrated
directly in MapServer or kept as a separate project built on top of
libmap.so. As I said and wrote in previous discussions, there as many
good reasons for than against direct integration.
So I'll vote +0 because I can't make my mind one way or the other. Note
that I am +1 on the rest of the implementation plan, so whatever the
rest of the group decides with respect to direct integration or not will
be good with me.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
