RFC 13 : SOS support
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Fri Feb 24 15:31:20 EST 2006
> Would it have made sense to use the layer's group variable as the group
> id instead of a metadata for the grouping?
> I presume the other metadata for the group (name and description) will
> be taken from the first layer in a given group in the mapfile, the same
> way that this currently works for grouped WMS layers. Should this be
> specified?
  It make sense. I have changed the RFC to reflect this.
> It's rare that this happens, I usually have good opinions on things, but
> in this case I can't make my mind on whether this should be integrated
> directly in MapServer or kept as a separate project built on top of
> libmap.so. As I said and wrote in previous discussions, there as many
> good reasons for than against direct integration.
> So I'll vote +0 because I can't make my mind one way or the other. Note
> that I am +1 on the rest of the implementation plan, so whatever the
> rest of the group decides with respect to direct integration or not will
> be good with me.
> Daniel
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
