Mapserver and WFS with TYPENAME and FILTER
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Feb 28 05:12:50 EST 2006
The WFS spec defines that you need to repeat your filter for all typenames:
A filter specification describes a set of features to operate upon. The
filter is defined as specified in the Filter Encoding Specification [3].
If the FILTER parameter is used, one filter must be specified for each
feature type listed in the TYPENAME parameter. Individual filters encoded
in the FILTER parameter are enclosed in parentheses ( and ).
Best regards,
Bart
> Hi there
> I am doing some WFS with Mapserver, and i have a question.
> When i list all the features in eg 2 layers (TYPENAME=layer_1,layer_2)
> Mapserver returns all features in the respective 2 layers that i have
> defined in TYPENAME
> http://vfp1.vestforsk.no/cgi-bin/mapserv.exe?map=E:\Inetpub\sites\vfp1.vestforsk.no\mapengine\mapfile_wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=layer_1,layer_2
> But if I add a FILTER to the request e.g. a BOUNDING BOX, mapserver only
> returns the features from the first layer in TYPENAME.
> http://vfp1.vestforsk.no/cgi-bin/mapserv.exe?map=E:\Inetpub\sites\vfp1.vestforsk.no\mapengine\mapfile_wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=layer_1,layer_2&FILTER=<Filter><BBOX><PropertyName>Geometry</PropertyName><gml:Box%20srsName='EPSG:32633'><gml:coordinates>76170,6813686%2077228,6814744</gml:coordinates></gml:Box></BBOX></Filter>
> My question is:
> Are there limitations on the use of FILTER and TYPENAME? Is it only
> possible to use FILTER withe one layer at the time? (The above example
> works fine, but it only returns features for 1 layer).
> Regards Sture
