The EPSG Contract
Arnulf Christl
arnulf.christl at CCGIS.DE
Tue Jan 10 13:28:51 EST 2006
Daniel Morissette wrote:
> And about WMS 1.3, because of the mess that Paul described below there
> is no plan to support WMS 1.3 in MapServer in the forseeable future (or
> more specifically, I am not planning to do it anytime soon). I think WMS
> 1.1.1 is still the most popular out there anyway and might be for a bit.
> Daniel
> Paul Ramsey wrote:
Thanks for the news, I did not exactly expect it to be good news
anyway... :-)
Does anybody know of a WMS that is accessible online/free for testing
purposes that can switch serving 1.1.1 and 1.3 on the fly "correctly"?
It gives me a headache overlaying WMS 1.1.1 and 1.3 in one client.
Probably we will have to stick to 1.1.1 until this issue has been
resolved at a "global" scale. Pity for the other stuff that gets
supported in 1.3 though.
Messymessymessy.
Best,
>> Well, the news from OGC on the WFS/GML issue seems to be to accept
>> the implemented facts on the ground for older representations of epsg
>> codes ("EPSG:XXXX") and enforce the "consistent" behavior for newer
>> representations of epsg codes (urn notation). And the WMS 1.3
>> specification remains as writ, so when Mapserver implements 1.3 it
>> will need to follow the specification, such as it is.
>> This implies, incidentally, some extra infrastructure at the backend,
>> because the current Mapserver source of EPSG CRS information, the
>> proj4 library, does not include ordinate order in its backend epsg
>> database (the epsg file). That leaves a pair of unpleasant
>> implementation paths: add a whole new concept into proj4, and then
>> have mapserver require the new library version in order to support
>> WMS 1.3; or do a hack solution and simply assume all +proj=longlat
>> combinations have reversed ordinates, unfortunately the hack will
>> omit other cases, like several south african and some european
>> projects, that also have a northing/easting order.
>> So long story long: no news :)
>> P
>> On Jan 7, 2006, at 8:30 AM, Arnulf Christl wrote:
>>> Any news here? Sorry if i missed it. We want to support 1.3 and are
>>> trying to get an overview of which services will support it in which
>>> way. We are the poor last layer and have to deal with whatever you
>>> spit at us.
>>> Best, Arnulf
>>> Paul Ramsey wrote:
>>>> I have also tried the Intergraph WFS and it is in easting/ northing, so
>>>> that makes 3 so far:
>>>> Mapserver
>>>> Cubewerx
>>>> Intergraph
>>>> Will be interesting to hear what the wfs list says.
>>>> Frank Warmerdam wrote:
>>>>> On 5/19/05, Paul Ramsey <pramsey at refractions.net> wrote:
>>>>>> Is it so bad to suck it up and follow the standards consensus, no
>>>>>> matter
>>>>>> how silly? Sometimes bad decisions are made, but walking away
>>>>>> from the
>>>>>> process destroys all the good decisions too.
>>>>> Paul,
>>>>> I do see your point, and I have certainly accepted that when
>>>>> MapServer
>>>>> implements WMS 1.3 it will have to address this issue properly.
>>>>> However,
>>>>> the WFS stuff has existed for quite a while (as has GML) but this
>>>>> issue
>>>>> is only being raised now in the WFS/GML context. So we are left
>>>>> having to back-fix without any obvious indicate of what is really
>>>>> the right
>>>>> thing to do.
>>>>> I *suspect* that at least for GML 2 the coordinate system does not
>>>>> control order of values in coordinate tuples. I'm sure I have heard
>>>>> previous detailed discussios to this effect. I am not at all sure of
>>>>> the situation with GML3.
>>>>> Hopefully we can isolate these issues to GML3 and WMS 1.3+ so that
>>>>> a simple version check will suffice to make the decision clear.
>>>>> Best regards,
