The EPSG Contract
Paul Ramsey
pramsey at REFRACTIONS.NET
Tue Jan 10 15:57:12 EST 2006
The cubewerx servers support both specs.
P
On Jan 10, 2006, at 10:28 AM, Arnulf Christl wrote:
> Daniel Morissette wrote:
>> And about WMS 1.3, because of the mess that Paul described below
>> there is no plan to support WMS 1.3 in MapServer in the forseeable
>> future (or more specifically, I am not planning to do it anytime
>> soon). I think WMS 1.1.1 is still the most popular out there
>> anyway and might be for a bit.
>> Daniel
>> Paul Ramsey wrote:
> Thanks for the news, I did not exactly expect it to be good news
> anyway... :-)
> Does anybody know of a WMS that is accessible online/free for
> testing purposes that can switch serving 1.1.1 and 1.3 on the fly
> "correctly"? It gives me a headache overlaying WMS 1.1.1 and 1.3 in
> one client.
> Probably we will have to stick to 1.1.1 until this issue has been
> resolved at a "global" scale. Pity for the other stuff that gets
> supported in 1.3 though.
> Messymessymessy.
> Best,
>>> Well, the news from OGC on the WFS/GML issue seems to be to
>>> accept the implemented facts on the ground for older
>>> representations of epsg codes ("EPSG:XXXX") and enforce the
>>> "consistent" behavior for newer representations of epsg codes
>>> (urn notation). And the WMS 1.3 specification remains as writ,
>>> so when Mapserver implements 1.3 it will need to follow the
>>> specification, such as it is.
>>> This implies, incidentally, some extra infrastructure at the
>>> backend, because the current Mapserver source of EPSG CRS
>>> information, the proj4 library, does not include ordinate order
>>> in its backend epsg database (the epsg file). That leaves a
>>> pair of unpleasant implementation paths: add a whole new concept
>>> into proj4, and then have mapserver require the new library
>>> version in order to support WMS 1.3; or do a hack solution and
>>> simply assume all +proj=longlat combinations have reversed
>>> ordinates, unfortunately the hack will omit other cases, like
>>> several south african and some european projects, that also have
>>> a northing/easting order.
>>> So long story long: no news :)
>>> P
>>> On Jan 7, 2006, at 8:30 AM, Arnulf Christl wrote:
>>>> Any news here? Sorry if i missed it. We want to support 1.3 and
>>>> are trying to get an overview of which services will support it
>>>> in which way. We are the poor last layer and have to deal with
>>>> whatever you spit at us.
>>>> Best, Arnulf
>>>> Paul Ramsey wrote:
>>>>> I have also tried the Intergraph WFS and it is in easting/
>>>>> northing, so
>>>>> that makes 3 so far:
>>>>> Mapserver
>>>>> Cubewerx
>>>>> Intergraph
>>>>> Will be interesting to hear what the wfs list says.
>>>>> Frank Warmerdam wrote:
>>>>>> On 5/19/05, Paul Ramsey <pramsey at refractions.net> wrote:
>>>>>>> Is it so bad to suck it up and follow the standards
>>>>>>> consensus, no matter
>>>>>>> how silly? Sometimes bad decisions are made, but walking
>>>>>>> away from the
>>>>>>> process destroys all the good decisions too.
>>>>>> Paul,
>>>>>> I do see your point, and I have certainly accepted that when
>>>>>> MapServer
>>>>>> implements WMS 1.3 it will have to address this issue
>>>>>> properly. However,
>>>>>> the WFS stuff has existed for quite a while (as has GML) but
>>>>>> this issue
>>>>>> is only being raised now in the WFS/GML context. So we are left
>>>>>> having to back-fix without any obvious indicate of what is
>>>>>> really the right
>>>>>> thing to do.
>>>>>> I *suspect* that at least for GML 2 the coordinate system does
>>>>>> not
>>>>>> control order of values in coordinate tuples. I'm sure I have
>>>>>> heard
>>>>>> previous detailed discussios to this effect. I am not at all
>>>>>> sure of
>>>>>> the situation with GML3.
>>>>>> Hopefully we can isolate these issues to GML3 and WMS 1.3+ so
>>>>>> that
>>>>>> a simple version check will suffice to make the decision clear.
>>>>>> Best regards,
