Problem with ECW
Andrea Cappugi kappu72 at GMAIL.COM
Fri Jan 13 07:30:06 EST 2006
I have compiled ECW SDK 3.3 on debian linux,
then i have recompiled gdal 1.3.1.0 and gdal(info,_translate,warp) works
with ecw.
When I try to use ecw image in mapfile, shp2img gives error segmentation
fault. So I have recompiled mapserver 4.6.1, but nothing change always
segmentation fault sig.
I have used valgrind to debug:
valgrind shp2img -m world.map -o pippo
==5501== Memcheck, a memory error detector.
==5501== Copyright (C) 2002-2005, and GNU GPL'd, by Julian Seward et al.
==5501== Using LibVEX rev 1367, a library for dynamic binary translation.
==5501== Copyright (C) 2004-2005, and GNU GPL'd, by OpenWorks LLP.
==5501== Using valgrind-3.0.1-Debian, a dynamic binary instrumentation
framework.
==5501== Copyright (C) 2000-2005, and GNU GPL'd, by Julian Seward et al.
==5501== For more details, rerun with: -v
==5501==
--5501-- DWARF2 CFI reader: unhandled CFI instruction 0:50
==5501== Thread 2:
==5501== Invalid read of size 4
==5501==    at 0x1C9EF94A: NCSThreadLSSetValue (in /usr/lib/libNCSUtil.so)
==5501==    by 0x1C9EFC78: (within /usr/lib/libNCSUtil.so)
==5501==    by 0x1C04BCFC: start_thread (in /lib/tls/libpthread-2.3.5.so)
==5501==    by 0x1C129F1D: clone (in /lib/tls/libc-2.3.5.so)
==5501==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
==5501==
==5501== Process terminating with default action of signal 11 (SIGSEGV)
==5501==  Access not within mapped region at address 0x0
==5501==
==5501== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 117 from 1)
==5501== malloc/free: in use at exit: 753207 bytes in 1168 blocks.
==5501== malloc/free: 193455 allocs, 192287 frees, 32573846 bytes allocated.
==5501== For counts of detected errors, rerun with: -v
==5501== searching for pointers to 1168 not-freed blocks.
==5501== checked 11946920 bytes.
==5501==
==5501== LEAK SUMMARY:
==5501==    definitely lost: 0 bytes in 0 blocks.
==5501==      possibly lost: 1400 bytes in 68 blocks.
==5501==    still reachable: 751807 bytes in 1100 blocks.
==5501==         suppressed: 0 bytes in 0 blocks.
==5501== Reachable blocks (those to which a pointer was found) are not
shown.
==5501== To see them, rerun with: --show-reachable=yes
Killed
Any idea.
Thank Andrea
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060113/b54f76bc/attachment.html
