antialiasing stuff
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Jan 13 16:38:11 EST 2006
I have not seen an equivalent term in the sld specs.
Steve Lime wrote:
>I think in the next version we could expose the hardness setting to mapfile
>tweaking... What's the equivalent terminiology in something like SLD?
>Steve
>>>>Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 2:43 PM >>>
>cool, thanks :) I hadn't tried it, thought I would ask first. I've
>managed to achieve almost the desired effect by jacking the hardness
>to 0.95 and fixing the gd bug for 1 pixel lines since I asked so
>maybe we won't end up going this route.
>Cheers
>Paul
>PS: any chance of having a HARDNESS keyword at the style level?
>On 13-Jan-06, at 2:55 PM, Steve Lime wrote:
>>This should be doable "as is". Just set TRANSPARENCY ALPHA and point
>>to the right image in your style or symbol definition. All the
>>fuzzy brush
>>support does is do this programatically.
>>I believe I've tested this before using an image or two that Sean
>>had created
>>while fixing another bug.
>>Have you tried it and it doesn't work?
>>Steve
>>>>>Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 12:59 PM >>>
>>Steve,
>>what would it take to support rendering lines with custom symbols
>>that have alpha transparency in them? We would like to be able to
>>make our own brushes that work in the same way that fuzzy brushes
>>work, but we pre-render them and access them as symbols. This would
>>allow finer control over styling without having to tweak mapserver
>>code to get the desired effect :)
>>Cheers
>>Paul
>>|Paul Spencer pspencer at dmsolutions.ca |
>>|Applications & Software Development |
>>|DM Solutions Group Inc http://www.dmsolutions.ca/|
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
