antialiasing stuff
Paul Spencer pspencer at DMSOLUTIONS.CA
Sat Jan 14 10:56:46 EST 2006
Would it make sense to change the meaning of the antialias tag in the
style and change it to a 0-100 value instead of a true/false?  If you
don't want to antialias a layer, then you wouldn't put ANTIALIAS
FALSE, you'd just remove it altogether.  So in the case of using
antialias as an integer value, it would make sense.
Paul
On 13-Jan-06, at 4:38 PM, Yewondwossen Assefa wrote:
> I have not seen an equivalent term in the sld specs.
> Steve Lime wrote:
>> I think in the next version we could expose the hardness setting
>> to mapfile
>> tweaking... What's the equivalent terminiology in something like SLD?
>> Steve
>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 2:43 PM >>>
>> cool, thanks :)  I hadn't tried it, thought I would ask first.
>> I've  managed to achieve almost the desired effect by jacking the
>> hardness  to 0.95 and fixing the gd bug for 1 pixel lines since I
>> asked so  maybe we won't end up going this route.
>> Cheers
>> Paul
>> PS: any chance of having a HARDNESS keyword at the style level?
>> On 13-Jan-06, at 2:55 PM, Steve Lime wrote:
>>> This should be doable "as is". Just set TRANSPARENCY ALPHA and point
>>> to the right image in your style or symbol definition. All the
>>> fuzzy brush
>>> support does is do this programatically.
>>> I believe I've tested this before using an image or two that
>>> Sean  had created
>>> while fixing another bug.
>>> Have you tried it and it doesn't work?
>>> Steve
>>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 12:59 PM >>>
>>> Steve,
>>> what would it take to support rendering lines with custom symbols
>>> that have alpha transparency in them?  We would like to be able to
>>> make our own brushes that work in the same way that fuzzy brushes
>>> work, but we pre-render them and access them as symbols.  This would
>>> allow finer control over styling without having to tweak mapserver
>>> code to get the desired effect :)
>>> Cheers
>>> Paul
>>> |Paul Spencer                           pspencer at dmsolutions.ca   |
>>> |Applications & Software Development                              |
>>> |DM Solutions Group Inc                 http://
>>> www.dmsolutions.ca/|
> Assefa Yewondwossen           Software Analyst
> Email: assefa at dmsolutions.ca    http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
