Authentication (Re: Feature polls...)
Philip Mark Donaghy philip.donaghy at GMAIL.COM
Thu Jan 19 18:01:09 EST 2006
On 1/19/06, Sean Gillies <sgillies at frii.com> wrote:
> Instead of building authentication (and realms) into MapServer, why
> don't we instead work to open MapServer up to Tomcat (or .NET,
> whatever floats your boat), and take advantage of the authentication
> frameworks that already exist? We can keep bolting ever more, and
> redundant, code onto MapServer, but I think it makes more sense to
> make MapServer work better within already existing frameworks.
> Sean
Sean, I read your mail again and I agree totally. MapServer does work
well in other languages, it could also work better in other
frameworks. I integrated into the Jetspeed portal. I have to admit
that I used mapserv on the command line. It worked fine. There is lots
more that can be done with MapScript. What I said about Authorization
remains the same. Use cases are necessary.
> On Jan 19, 2006, at 2:30 PM, Philip Mark Donaghy wrote:
> > Oops, I sent this only to Steve the first time.
> > Yes, I am interested in putting this in writing. I'll help any way
> > I can.
> > I can say now that I would like to have one or more REALM definition
> > in the map file.
> > A realm processor would have an isUserInRole function. Realms types
> > could be ldap, database, or file. Different realm processors would be
> > invoked according to the realm TYPE.
> > MapServer users could configure any layer with one or more ROLES.
> > There is the notion of the Principal. That is the current user making
> > the request. Getting the principal from the request will be possible
> > using Basic authentication since the username and password is sent
> > with every request following authentication. In the Tomcat/AppServer
> > world this can be done otherways, one of which is by using a session
> > to store the user credentials. But correct me if I am wrong MapServer
> > does not maintain a session accross requests.
> > I can't really think of anyway to do this without using https or
> > sessions. Any ideas?
> > On 1/19/06, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
> >> We'll hold you to Monday- only 4 days left. ;-)
> >> Are you or someone else willing to do a bit of research on the
> >> subject an=
> > d possibly author an RFC?
> >> Steve
> >>>>> Philip Mark Donaghy <philip.donaghy at GMAIL.COM> 01/17/06 6:55 PM
> >> This is a very interesting topic. I have some experience working with
> >> application servers and web application frameworks at Apache
> >> Jakarta(yes this is java but the theory is the same for any
> >> language).
> >> Application servers define realms that are configured and made
> >> available to the applications running in it. The realm is an
> >> abstraction of the user, group, and role authentication mechanism
> >> backed by any number of storage mechanisms (db, ldap, xml file). The
> >> realm must define at least one critical function, isUserInRole(user,
> >> roles). Applications are then configured to accept or deny resources
> >> based on the current users roles.
> >> What is important here is the authorization mechanism is simply
> >> delegated to a third party tool. MapServer needs the ability to
> >> configure different kinds of realms and apply authorization model to
> >> any type of layer or feature. MapServer users can then configure
> >> roles
> >> for layers or features(or rules applied to attributes of features).
> >> So all this has to be used in conjunction with authentication so that
> >> map server knows who is the current user making the request.
> >> I'll have this done by monday :)
> >> On 1/16/06, Mark MacLennan <maclenna at visi.com> wrote:
> >>> At 10:39 PM 1/15/2006 -0500, Kralidis,Tom [Burlington] wrote:
> >>>> Has anyone checked out DACS (http://dacs.sourceforge.net/)?
> >>>> They have=
> >  a
> >>> C/C++ toolkit/API in which one can build modules to stuff like do
> >>> per l=
> > ayer
> >>> authorization, etc.
> >>>> I've seen this successfully integrated with CubeWerx WMS/WFS.
> >>>> Would b=
> > e
> >>> neat to see as a pluggable Apache module for use w/ MapServer.
> >>> Very interesting! I had not come across DACS and it is exactly the
> >>> functionality I had in mind :-)
> >>> A related project I was aware of, although I am not sure how it
> >>> might a=
> > pply
> >>> to MapServer per se, is GeoXACML (http://www.geoxacml.org/). A
> >>> demonstr=
> > aton
> >>> has been implemented for a OGC Web Map Service. An OGC discussion
> >>> paper=
> >  for
> >>> GeoXACML also exists
> >>> (https://portal.opengeospatial.org/files/index.php?
> >>> artifact_id=3D10471)
> >>> related to the topic of authorization for digital rights
> >>> management in =
> > the
> >>> geospatial domain.
> >>> thanks!
> >>> Mark
> >> Philip Donaghy
> >> donaghy.blogspot.com del.icio.us/donaghy/philip
> >> Skype: philipmarkdonaghy
> >> Office: +33 5 56 60 88 02
> >> Mobile: +33 6 20 83 22 62
> > Philip Donaghy
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com/news
Philip Donaghy
