MapServer and Sensor Observation Service
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Fri Jan 27 14:31:25 EST 2006
Frank Warmerdam wrote:
> Could you briefly describe the SOS, and how it would be
> integrated with MapServer?  Is this another datasource,
> we we read from remote sensors and then plot the results
> as point features?  It is another way of publishing MapServer
> point data (where mapserver is the server)?  Both?
At this point we are only looking at publishing data through a SOS
interface. The data would come from one of MapServer's supported data
sources (preferably postgis) and be published via a SOS interface, there
is no talk of supporting connections to sensors or to remote SOS.
Note: The sensor data would be collected and stored in the database by
some pre-existing and sensor-specific mechanism independent of MapServer.
> If the implementation were able to be quite localized to one
> module in MapServer, and if it sorts of fits with the mapserver
> role of publishing geospatial data on the web, then I don't
> think I would mind it living within the mapserver tree.
Yes I think it would be localized to a mapsos.c (or mapsensor.c), very
much like WMS is local to mapwms.c and WFS is local to mapwfs.c.
The configuration would be done through a bunch of new metadata
elements, once again similar to the way WMS/WFS/WCS work. However the
amount of metadata required for a SOS might be larger than for a WMS.
Also, some external files might be used, for instance, the sensor
metadata would not be generated by MapServer, it would be stored in a
static XML (SensorML) file that MapServer would simply forward to the
client without trying to interpret it.
Of course, if it is decided to make this an official feature of
MapServer then an RFC will be written and the implementation plan
discussed here, but before writing an RFC we need to know if the rest of
the developers think this belongs in MapServer or not.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
