Voting on RFC 9.
    Steve Lime
    steve.lime at DNR.STATE.MN.US
    Tue Jan 31 21:47:40 EST 2006
As usual I write before I think about things. The main parser is setup to return an int, not a string, it's there for logical expression evaluation. I need to do more reading to see if one can have multiple parsers in one application (I'm sure you can)and what the ramifications of that are. Probably need a another lexer state... *yuck*
Needless to say this is not trivial so the item tag becomes a reasonable start, but it does nothing to help with bug 1634. I'm afraid fixing the data in the source data or via SQL on the way out is the best solution at the moment.
Steve
>>> Stephen Woodbridge <woodbri at swoodbridge.com> 01/31/06 7:03 PM >>>
Steve Lime wrote:
> I've got an idea that might kill two birds with one stone. We could
> consider using the MapServer parser. That is, add some functions like
> commify, uc, lc, substr, replace to the bison grammar. Then one could
> write full-blown expressions for both labeling and template output.
> You'd still need an item tag but the format would be an expression
> similar to what you see with TEXT...
Steve,
I like the idea of implement once and use everywhere. This is less work
AND it makes for a much more consist user experience because the rules
for how to use the mapserver become more consistent, rather than
explaining that they are different for historical reasons, and we can
change then NOW without breaking backwards compatibility :)
-Steve W.
> Steve
>>>> Tamas Szekeres <szekeres.tamas at FREEMAIL.HU> 01/31/06 5:17 PM
> Please consider
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1634
> as a potential candidate to RFC9
> Tamas
> On Tue, 31 Jan 2006 07:03:15 -0700, Sean Gillies <sgillies at FRII.COM>
> wrote:
>> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-9/
>> +0 from me. I think your/our time is better spent making mapscript
>> better and using mapscript with existing Perl/Python/PHP templating
>>  packages, but you know that already. For C, there is Clearsilver
>> http://www.clearsilver.net/
>> Maybe a switch to something like clearsilver would be a good 5.0
>> feature.
>> Sean
>> On Jan 30, 2006, at 10:51 PM, Steve Lime wrote:
>>> So far only one +1 (me), and one +0 (Frank). I've got this ready
>>> to go = into 4.9 with one more thumbs up. Anyone?
>>> I'd like to get it committed and move on to something else.
>>> Steve
